Zero Point Calibration: What's the Benefit If No Lights On?
Bluesky 07
I've never done a ZPC in the 9 years I've had my 4R. I've seen posts and threads about doing a ZPC to resolve VSC lights showing, but this, from the 2008 TSB covering 4th Gens, says a ZPC is needed even if no lights are on:
"Perform this procedure if any of these repairs have been performed on the vehicle:
• Wheel alignment has been adjusted.
• Any chassis components have been removed/installed or replaced."
So my question is, what's the benefit or purpose of doing the ZPC if no lights are showing? It's easy enough but is it worth the time and trouble?
When taking a quick turn with a modified vehicle, especially heading up a short incline like a driveway at the same time, the dash can beep at you and cut power for a split second.
I believe ZPC can reduce this situation though my truck still does it from time to time.
If you do the VSC off mod, it won't matter if you do the ZPC because you drive around with VSC off at all times anyway :naughty: Sometimes I hate all the nanny features that prove to be an annoyance more times than not.
