Old 05-22-2021, 03:48 PM #1
chrisbagnell's Avatar
chrisbagnell chrisbagnell is offline
Real Name: Chris
chrisbagnell will become famous soon enough
Real Name: Chris
Post How to Manually Release Rear Hatch with Pictures
Introduction
Hello All, I wanted to show how to manually release the door hatch as it was discussed briefly on this form in the past but I could not find proper instructions with pictures. In my scenario, a friend closed the 4runner net in the hatch lock and now the hatch will not open, it makes the electronic release sound but no matter how hard I pull it will not give. It took about 30 minutes start-to-finish as there was limited information online and I suspect It should take under 30 for anybody else... each image should be clickable to open a larger version in Imgur.
There are a lot of tutorials out there on how to remove the hatch panel when the hatch is already opened but it is not as easy closed.
Hopefully this helps everyone in the future who has this problem, if anyone has any questions, please let me know!
Tools
  • Flathead Screwdriver
  • 10mm Socket
  • Socket Extension
  • Trim Removal Tool (Optional)
Step 1: Accessing Rear Hatch Panel
To start off you need to figure out a way to the rear hatch from the inside. I put down the rear seats and made my way to the hatch panel. Upon looking at the panel you can see there are 2 covers that need to be popped off, one is in the middle and the other is where the strap is screwed in, using the flathead pop them off.
Next to take off the strap you need the 10mm socket and extension and start taking that off.
Step 2: Removing Rear Hatch Panel
Now that the only bolt is taken out, the panel is held in by the same clips used on most of the panels in the car, they pull straight out but it is tricky at this angle in the car. I grabbed by the middle hole that had the cover, and yanked it back and it popped all of the clips off except the lower right corner. I continued pulling at it and it eventually came off.
Step 3: Disconnecting Power
Now that the panel is off, there is one connection to the motor to the right of the plastic shielding. A clip has to be lifted with a screwdriver to release it and allow to disconnect the power.
Step 4: Accessing the Hatch Motor
The motor is behind the plastic shielding talked about in the previous step in a white case towards the base of inside the door. If you have worked on door panels before, this is the same plastic and adhesive glue. This glue will get everywhere if you are careless. What I did was pulled it from the Right to Left, not all the way just past the motor, and rolled it on itself.
Step 5: Removing Manual Release Lever Cover
Next to remove the cover is somewhat complicated as there is not much wiggle room and it only comes off one way. The good thing is that it is plastic so it does flex and you can maneuver it off incorrectly and it will not break. I disconnected the wire near it from the top of the box to give me a little more clearance. The box is made of 2 pieces, the first holding the motor assembly and the second covering the levers. To remove the smaller cover on the left you need to pinch it near where it connects and wiggle the back side (side closest to the outside) off the plastic arm and then off the arm in the front. Finally tilt it up and it can be removed. I know this might sound complicated so hopefully the pictures will help more.
How to Manually Release Rear Hatch with PicturesHow to Manually Release Rear Hatch with PicturesHow to Manually Release Rear Hatch with Pictures
Step 6: Opening the Hatch
Now you can see there are 2 levers visible. Some posts said the smaller one was the only one that needed to pushed but, in my case, it was both. This might depend on what is stuck in the latch or if it just died, but from my observations the smaller on the bottom released the electronic locking mechanism and the big one released the actual lock holding the door shut.
It's important the glass is up in this step as you'll need to push the hatch and don't want to risk breaking the glass. I engaged the small lever and I pushed from the closest I could get to the lock from the inside metal and it took some force but eventually the door released, then I used the big lever and it allowed me to fully open the door.
Congrats! You did it, make sure you put it back together in the same order you took it apart and reconnect the power to the hatch, oh, and also make sure you get what is stuck out of the hatch lock.
I hope this helped and Let me know if you have any questions. Now I just have to make sure that never happens again and teach my friends how to close a 4th gen hatch properly.
chrisbagnell is offline   Reply With QuoteReply With Quote
Old 05-23-2021, 08:17 AM #2
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
This is good stuff! Thanks for sharing!
Lots of pics, I love seeing it. Even hosted on Imgur with LinkedBBCode, I love it!
y=mx+b is offline   Reply With QuoteReply With Quote
Old 05-26-2021, 03:49 AM #3
nwt4runner nwt4runner is offline
nwt4runner is on a distinguished road
Really nice write up, thanks for sharing!
nwt4runner is offline   Reply With QuoteReply With Quote
Old 05-26-2021, 08:18 AM #4
rwh963 rwh963 is offline
rwh963 has a spectacular aura about rwh963 has a spectacular aura about
you mean "your ex-friend"!
rwh963 is offline   Reply With QuoteReply With Quote
Old 05-26-2021, 02:00 PM #5
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
I attached a piece of cord on the mechanism then put the cover back on. Once the cover was on I taped the cord to the cover. I can manually pull the hatch without too much messing around if needed.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 07-14-2021, 05:28 PM #6
stormydawg stormydawg is offline
stormydawg is on a distinguished road
This morning I slammed the hatch shut in a normal fashion and heard something rattling. Rather than just let it rattle till something serious effed up I found this thread and ten minutes later I had the hatch cover off and found a nut that turned out to hold one of the studs for the "4runner" emblem/license plate light. 5 minutes later I was finished.
Thanks much for posting this!
Note: If you have one of those tool kits with the plastic pry bars for removing trim parts it makes this a breeze.
stormydawg is offline   Reply With QuoteReply With Quote
Old 02-04-2022, 11:08 PM #7
Ron Helmuth's Avatar
Ron Helmuth Ron Helmuth is offline
Real Name: Uhhh this is my real name
Ron Helmuth is on a distinguished road
Reviving the thread-most helpful chrisbagnell! Excellent photos and details on each step-saving as a Mozilla favorite, just in case this ever comes up. Thanks again sir.
06 4th gen V8 4WD of course...
08 Honda Ridgeline RT
05 Scion xB-the toaster-daily driver
my Yota Fanatic photos are on Facebook- here is link:
http://www.facebook.com/album.php?ai...5&l=5795132731
Ron Helmuth is offline   Reply With QuoteReply With Quote
Old 02-04-2022, 11:25 PM #8
should this be a sticky?
Old 01-22-2023, 07:31 PM #9
Dchaffin Dchaffin is offline
Dchaffin is on a distinguished road
Hi, I just completed all the steps and I’m at the two levers by the hatch lock but it’s not budging no matter how hard I move the levers. What direction do they need to be pushed in? I have a piece of fabric stuck inside the lock.
Dchaffin is offline   Reply With QuoteReply With Quote
Old 01-23-2023, 06:57 AM #10
Real Name: Skip
Real Name: Skip
Have someone push in on the hatch then pull the levers and then have them pull on the hatch to help toggle the catch, the fabric is probably not letting the motor move the catch.
2004 Limited V8
Old 01-02-2024, 10:53 PM #11
Runnerdad79 Runnerdad79 is offline
Runnerdad79 is on a distinguished road
It works!
So I've been trying to come up with a easy camping hack for my 2007 and thanks to this post I was able to knock it out within 20 minutes tonight! I just popped the panel like you said and reach down to the actuator lever and ended up using the original pull strap for the hatchback to loop through and pop a hole in the plastic weather strip notch the little plastic cover so that nothing is dragging or catching and it works perfect! Easy access with a little panel that covers back up so there won't be any accidental openings thanks a lot again for posting this!
Runnerdad79 is offline   Reply With QuoteReply With Quote
door , hatch , make , motor , step
How-To: Interior rear hatch release RyanNapoleon 3rd gen T4Rs 17 06-14-2022 08:26 PM
Rear hatch interior release Tejas 5th gen T4Rs 18 01-18-2022 01:29 AM
how to lower rear hatch window manually blazinjames Classic T4Rs 5 05-23-2014 05:35 PM
Manual release for rear hatch on 04? Jaydee914 Problems & Warranty Issues 7 05-25-2004 06:37 PM
