Tailgate light mod
utobiaus
I put two courtesy lights in my tailgate. This makes everything better. They are on a switch so they function like dome lights: on-off-door.
Here are some parts you'll need
2 courtesy lights (from underneath your door arm rests)
4 scotchlock connectors
7 female connectors
15' of red and green awg wire (or any colors you want)
coat hangar
1 SPDT or DPDT switch (I used DPDT b/c I had an extra)
And miscellaneous tools (crimpers, cutters, dremel...)
Leds (I used v-leds HP LED 6K WHITE MULTI SOCKET 158 168 194 906 921 3175 211 1895 57 1156 but in 5k color.)
A big shout out to JA from the forums and Top4runners for this. He did all the hard stuff and I just built on it.
1) I tapped into the dome light for power and ile. The ile is how your lights come on when your doors open. The ile also serves as the negative for your leds. I used scotchlock connectors to tap into them. I used green for the ile and red for constant power. The middle wire of the ribbon is the ile and one of the outside wires is constant 12+. I think it is the left one. Check before you connect and let me know and I'll edit.
2) Run the red wire 12+ with enough wire to go under the ceiling to the exterior boot and down into the tailgate and then all the way across. But don't run it yet!
3) Run the green ile to the driver's side rear back-up mirror. This is where I put the switch. You will also ground the switch here. You can easily pry off the mirror and there is tons of room. I attached a schematic JA wrote up that shows you how. I cut in just below the mirror to place the switch. This location is awesome b/c it's out of the way and stuff won't bump into it. There is also a threaded hole that you can connect your ground to.
4) To wire the switch: top ground, middle to tailgate lights, bottom green wire from dome light ile
5) Run green and red wires from the tailgate up the side and up the boot into the ceiling. It is much easier to do this than down from the ceiling first. You will need a coat hangar to run it thru the boot. You will need to pry off the tailgate cover and the motor cover to run the wires. Make sure you have enough wire to run it to both sides of the tailgate and up into the ceiling. Also tape the wires together about every 6". This will help keep them together or they will snag on the window.
6) Connect green wire to middle connector on switch.
7) Red wire to constant on wire in ribbon.
8) Cut holes in tailgate for the lights. Trace first and then cut. Put the lights on the raised portion of the tailgate or they will not have enough room. As it is the driver's side one doesn't have enough room anyway. It sticks out just a little but no one has noticed in the month I've had this up.
9) Make sure of the fit before you put it back on.
10) Wire the driver's side light by using red/ green wires and then scotchlocking onto the longer wires. Then end the long wires with the female connectors to the passenger light.
11) TEST before assembling. Leds are polarity sensitive so if it's wired wrong one could light up and the other will not.
12) When assembling pull the wire tight inside the tailgate next to the window. The window snagged on my wires and wouldn't go down all the way.
Please leave comments. I did this really fast and I'm sure I left out lots of stuff. This took me 8 hours but that's with running to the store for new parts b/c I'm a knucklehead kept forgetting things lol. The picture of before and after doesn't do it justice.
Ok I'll get started on it tomorrow. Took me about 6-7 hours. Hopefully easier for the next guys. And hopefully some good suggestions. I know I messed up a bunch.
I gotta ask, why did ya got with this light vs an LED strip ?
from my understanding, the LEDs are pretty cheap, use lots less power, are brighter, and can come in different colors (red for easy on the eyes)
I did use leds. I have used led strips for my glove box light and they don't look as good and they break easier. It also looks more stock than the strip. However you could do the same thing and just drill a small hole for the wires and hook up the strips if you wanted.
I'm with the LED strips on this. Seems simpler and no cutting or robbing Peter (your doors) to pay Paul (your tailgate).
Probably wouldn't even have to drill a hole either, perhaps run the wires through the edge of the trim. :bigok:
Oh I agree the strips would be easier but they are too easy to break IMHO (In My Haughty Opinion). I broke several before I went this route.
i went with this one, its posted under the liftgate thread..it has held up well, has taken a beating and at night before I ride my mtb, the red light function works good to keep my eyes acclimated to the dark, and provide light, it also lights enough area around the rear for tail gating afterwords! Much more than the LED strips do..and I didnt cut any large holes...just a small one for the wire..
Series 16 Maputo LED Multi-Purpose Light
7ron
