Doctor Subie's Build Thread (sorta)
Doctor Subie
Long time lurker, some-time poster, and thought I'd throw in my small contribution to this great forum...
With the help of this forum, I've been able to do some mods to my truck--most of them have worked out well, some have been more trouble than it's worth, but none have been a fail...
So without further ado, let me throw up some pics:
4runner1-1.jpg~original
Bought her brand new in 2007--v8 limited fully loaded w/ nav, rear DVD, sunroof.
Kept her mostly stock, except for some Weathertech mats, Volant CAI, Westin stainless bull bar, a dual side-exit Borla exhaust and a kick-ass Viper 5902 remote start/alarm, until winter of 2010, driving back from Tahoe to Seattle, some dude's wheel flew off his trailer and took out my driver's side step, rear quarter panel, and punched a fist-sized hole in my rear tire
4runneraccident001-1.jpg~original
After finding out a factory side-step ran $700, I decided to take the insurance payment (luckily I had uninsured motorist coverage) of ~$2200 (side step, new rim/tire, rear quarterpanel) and use this opportunity to 'rebuild' my 4runner into something burly...
I purchased the quarter panel and clips, and fixed up the body work damage myself...
I then removed the factory side steps, and ordered up some Stubbs HD-SKO sliders, which I primed and then painted with Herculiner. The sliders were well made, and Stubbs was great to buy from--good communication, and a real nice guy to chat with. My only 'issue' was that I wish it would have protruded out more to make it more functional as a 'step', but I can see how that would take away from it's intended use as a slider. Oh, and also, finding a shop to weld it on for a reasonable price was a pain, not to mention they f'd up on the initial welding and had to re-do the driver's side (long story). Overall, however, I'm glad I have them on, they look great, and I don't doubt their ability to do their job.
4runner010-1.jpg~original
The mods then started to come in bunches:
1) Walker Evans 2.5" front coilovers and rear shocks w/springs, All Pro front swaybar endlinks. This raised the rear by 2", and I ended up adjusting the front up by ~3". I don't have any experiences with other 4runner shocks, but went with Walker Evans 'on a whim' after chatting with Sara, the sales gal at AllPro. The Fox setup would have been a little bit more, but not by much. I didn't want a remote resi setup because I wouldn't need the extra cooling ability of the reservoir, and also because I didn't want to hassle with having to mount the reservoir. The W-E shocks ride really firm, almost like my wife's Audi A4 with a Stasis coilover setup (in other words, european sedan firm), and of course the handling has improved. It does seem a bit harsh over bumps, surprising for a 'off road shock', but I've yet to do any off roading with them to give a good review. Currently I've got about 500 miles on them, so they are not completely broken in yet, so I anticipate it'll soften up some.
4runner001-1-1.jpg~original
2) All Pro UCA. See a pattern here? I just bought the whole setup at once from All Pro, netting me a small discount for doing so. The UCA's were well made, has built-in zerk fittings, but were a pain to install-mainly due to getting the existing ball joint separated. I ended up using a ball-joint separating tool, which ultimately tore thru the rubber boot of the joint. Also, these UCA's do quite a bit of squeaking, despite prolific lubing of the zerk fittings--I was told it was because of the polyurethane bushings. Not a deal breaker, though.
3) Stainless steel brake lines from AP. Necessary for use in the rear, and optional for the fronts, but I figured I might as well throw those on. Firmed up the brake pedal feel a bit, and a easy, inexpensive mod.
4) Timbren bump stops, front/rear. Got this idea from BlairB's build thread. To be honest, since I don't usually carry a lot of weight in the truck, nor have heavy aftermarket equip. like winch/bumpers etc..., this mod didn't yield any tangible benefits. Plus, these are expensive for what you get--essentially rubber bumpstops. If I had to do it over again, this is one mod I probably would put at the bottom of my list...
5) 17" Liquid Metal Gatlin rims in matte black, BFG T/A KO 275/70/17, AP 1.5" wheel spacers. Bought the rim/tire from Discount Tire. In my opinion, this dramatically changed the look of the car the most (esp. the rims). I chose matte black so it could run dirty and be less noticeable, and I especially liked the chunky spoke pattern. I also stepped down to 17's to widen my tire choices. I chose the BFG's at the recommendation of the sales guy, and got a fair price (better price than TireRack). They look great, and so far, I've been happy with this selection. I didn't want to go M/T tires because I want to be able to use this in snow conditions, and didn't want to compromise on mileage or road noise like I would have with M/T tires.
4runner007-1.jpg~original
6) PU sway bar and rear endlink bushings. Cheap, easy to install. Didn't improve my ride very much, mainly because my W-E setup was already in place, and very firm to begin with. Suspect it would have made more difference in a stock suspension. Still, so easy to install, and cheap so it didn't hurt.
7) Xenon Depot HID light kit 5000k. Great mod. Let me repeat that: GREAT MOD. Much brighter than stock halogen setup, easy to install. Definitely worth it.
8) Plastidip emblems, TRD stickers, rear panel. Love 'em or hate 'em, I'm pretty sure they add about 10rwhp to the truck. $15 off Ebay.
4runner012-1.jpg~original
9) mesh behind front grill. Not quite the 'Satoshi mod' or whatever, but then again much easier. Bought some gutter guard mesh from Lowe's, plasti-dipped and clear-coated them, then cut to size and zip tied it in behind the front grill. Hopefully will keep bugs and small rocks from flying in to the radiator...
4runner004-2.jpg~original
Next up will be some Rigid Dually LED fog lights to go in behind the lower grill, and a Defiant light bar w/ a pair of Omix-ADA 5" HID lights.
More pics of the truck:
4runner005-2.jpg~original
4runner008-1.jpg~original
nice looks good!
i dont plan on changing my rims until i have to buy new tires. still debating if i should go with after market rims or just pick up some limited ones. i love the look of the limited rims.
Love the T4R man! definitely one of the nicer setup's i've seen on here! You are representing Seattle well man! thanks for the pics!
Would you describe it as front high? I can't tell if the picture was taken on a hill. Less gap in the back.
yeah, there's a slight incline where the truck's parked, so it makes the front look a tiny bit high--on level ground, it's pretty level...
thanks for all the comments guys!
Next on the plate are the Dually's that I have to figure out how to wire up to the FJfog switch I bought:
4runner026-1.jpg~original
Love the build!! Curious to see how firm the Walker Evans suspension rides compared to other suspensions.
The Timbren impression is good info for the other members who are riding basically stock weight trucks.
Here is a diagram i put together for another forum member that might help:
Piaa-FJswitch_diagram.jpg~original
Just let me know when you plan to do the lights (dually and/or Defiant). Always willing to help out another member.:cheers:
hey thanks Darkie, u are more than welcome to check out my 'shop setup' in my garage, and if you need to get your truck up on a lift!
I'm waiting on the Defiant bar (should be arriving in couple of days), so I can't wait!
I'm also planning to run a Bluesea fuse box like yours (debating on whether to do 1 12 circuit box w/ 6 on/6 AC vs. 2 6-circuit boxes...), and then some armor--maybe Budbuilt or Man-a-fre's....
Hey Doc, I am in the market for lights and came across those dually's that you have. They seem to be a good bang for your buck. Are you happy with them (do they seem bright enough)? Where did you end up mounting them? If you have any pictures to show that would be awesome!!!
Thanks
Thanks
It depends on what you're trying to achieve. If you don't have fogs, then I think they will fill in nicely for what the stockers would do. For my rig, however, the duallys get lost in the wash of the front headlights (which I did the HID conversion), so I don't get much out of them. Probably a lot of that has to do with where I mounted them, and the other thing is that I got them in a flood light pattern. If I had to do it over again, I would've sprung for the D2s in a driving beam pattern...
here's some pics as to how I mounted them--basically mounted them on the front bumper support beams right behind the lower grill (there were some nice holes already there so I could slip the bolt through). Sorry, haven't had time to take a pic of them lit up, or of the final bit of install, but this gives you some idea:
P1010567.jpg~original
P1010563.jpg~original
Those are neat rims, where'd you find them?
Discount Tire--they have a bit more offset, so they will stick out a bit, but I think it fits well, even with my 1.5" spacers. Plus, the matte black finish means I can let them get all grimey/brake-dusty and not feel compelled to clean them!
Doc: that's a cool idea, if I'm understanding correctly what you did (duallys are flush, not sticking out from bumper) sort of a "built in look". ?
Yep...I'll try to snap some pics--though the downside of mounting them 'stealth' is it probably limits/blocks some of the light output--hence why I'd go for a driving pattern rather than fog pattern (depending on what you want to achieve)
Ya I see what you mean. Ideally, if I had the $$$, I would mount two of the 10 inch rigid light bars in the same location you mounted yours. I think that low profile/flush look would be pretty sick, and it would be plenty bright too!
DionicioLives
