Best Replacement "plug n' go" headlights
zerowkul98
Ive seen some great bright headlight-talk in the forum in days past, but most require more than just "pull out old bulb, put in new bulb".
Im looking for the brightest replacement bulbs that will require me to just open the hood, pull the old bulb and plug in the new one.
Any thoughts?
From Daniel Stearn (headlight professional):
Your low beams take a 1350-lumen H11 bulb. You can easily, safely, and effectively replace this with a 2100-lumen H9 bulb, which you ought to be able to find locally by seeking the high beam bulb for a 2008 Chevrolet Malibu. Use a good brand (GE, Philips, Osram-Sylvania) and stick to colorless clear bulbs, not any kind of "whiter light" bulb such as the Sylvania Silver Star scam. You may need to shave a small ridge of plastic off the H9 bulb's connector so that the H11 socket will snap on. Other than that, it's a direct swap. The only disadvantage is shorter low beam bulb life — the H11 is optimised for very long life with relatively modest light output, while the H9 is optimised for very high output with relatively short life. Note that the H9 swap is not universal; it works well in projector-type low beams but is not safe in most reflector-type low beams or in fog lamps of any type.
If you want to upgrade the high beams, go to your local Chevrolet dealer (or GM Parts Direct: Your direct source for Genuine GM Parts for a better price)and pick up two part number 15094219. That is a 9011 bulb. They are not some tinted or overwattage version of 9005, but share the identical filament geometry and base architecture as well as the same power consumption.
Here's the comparison:
stock: 9005, 12.8V, 65W, 1700 lumens, 320 hours
new: 9011, 12.8V, 65W, 2530 lumens, 320 hours
The 9011 bulbs have a double-wide top ear on the plastic bulb base, this is
to comply with the law requiring different bulbs to have different bases.
The extra-wide plastic top ear is easily trimmed or filed to make the bulb
fit your headlamp's bulb receptacle. Once that's done, they go directly
into the headlamp, and the existing sockets snap on. Please see
HIR bulb base modification for details.
Note- This was for my 06. Check your headlights. I don't know what the 03 has.
I did the h9 swap and it is remarkably better. Took about 10min per light since you have to file a little ridge but super easy. Definitely recommend it.
I finally went to a full HID replacement, but I was happy with Silverstar Ultras. I didn't have them in long enough to worry about them prematurely burning out.
so you dont want to have to mod the bulbs at all? it takes couple of minutes at most & is well worth it. for the 03- HIR 9011 and 9012 bulbs are exactly identical in all dimensions to 9005 and 9006 bulbs, except for two areas, the second of wh for the 08- http://www.toyota-4runner.org/4th-gen-t4rs/59202-08-low-beams-h11-h9.html , but if you dont want to or cant mod the bulbs, then for 03 id suggest one of these for the 9005- 9005 (HB3) Bright Light BOOSTED 9006- or <b>Philips <font color="red">Xtreme Power</font> 9006 55W / HB4</b> (TWO PACK) Amazon.com: PIAA 10926 9006 (HB4) Intense White - 9006 51W=115W Xtra Intense White Bulb, Twin Pack: Automotive for the 08- <b><font color="red">Osram Night Breaker® +90 "<u>PLUS</U>" - EXTRA LIFE - ultra High Output 55w H11 Bulb ---- SINGLE PACK</b></font> Amazon.com: Philips H11 CrystalVision Ultra Headlight Bulb, Pack of 2: Automotive. no matter what type of bulbs you need, (9005/9006/H11) if you want brighter, usable light output, (not temp/color) look for ones with the highest lumens. ive never tried these but hoen makes a higher wattage H11 for the 4runner - http://www.hoen-usa.com/ti.htm http://www.hoen-usa.com/lowhigh.htm
I changed out my headlights (low-beams) and fogs a couple weeks ago. I just went with the PIAA Night Tech for the low beams and Höen Yellow Fogs. Bought the PIAA's from Amazon and the Höen's right from their site. Everything was plug and play. Simple, fairly cheap and Looks Great!! Also they are all 55w so I shouldn't ever have any issues with melted wiring harnesses.
http://www.amazon.com/gp/product/B00544ZE58
http://www.hoen-usa.com/fog.htm The Höen Endurance Fog's at the bottom of the page, bulb 9006.
Don't waste your money on HID's (xenon). They don't work. I got the H9 Philips off Amazon, perfect. Repeat, HID's will not work in our stock projectors and reflectors, basic high school geometry.
Bulbs
Narva Rangepower +50s. :biggrin2:
The 9011/9112 conversion was my second choice and seemed like a good way to go too. The only thing I didn't like is that they are 65W bulbs and I wanted to keep the bulbs at the stock 55W.
Any thoughts?
i got the Black Halo Projectors with Angel Eyes and I love them. They look great on my black '03 SR5. I havent taken pics yet but I was gonna do that today. I plan on posting the pictures when i have them. the halogen bulb is also much brighter than the stock headlight. and so far i have recieved nothing but compliments about them. also, i did not purchase the HID kit with it because i am not crazy about the blue light
Well mine works- pretty good actually - i good quality HIDs from xenon depot 4300k , but to your input if you are replacing the light with a much brighter light, so yes basic geometry would say you would get brighter light output keeping the space specifications ( reflectors etc)- i am sorry i am not trying to be a smart a@@
its just that i tried every kind of bulbs for our 4runners out there and the light output while increased was not satisfactory..
i have HIDs in both fogs and headlights and i am pretty happy, would i mind a projector no.. but i am not sold on the ones out there right now
