Originally Posted by 2013Trail
All the windows can be opened with the key fob?
Yes, but the option must be enabled in techstream. (Which, if you have the software you can do, else go to your dealer.) The option allows you to roll all 4 windows down and either tilt or open the moonroof depending on programming. You can also have the mechanical key "up/down" option programmed as well which will allow you to use your key in the drivers door (on all models, including limited) to roll up the windows and close the moonroof.
