ARB Summit Bumper
I think that's exactly it. I brought it back in to the shop who install and had them change the angle to point down more to clear the top so the aerial brackets weren't rubbing. Didn't occur to me until seeing other pictures that mine was too low.
I have a set of McQueen fenders on order so they'll have to remove the bumper to install anyway. Hopefully they fix it (correctly) this time.
Another note. Look at your sig pic. You can see those big gaps in the bumper cut up front by the grill? Looks like they prob followed arb's instructions for that part but it's all exposed because they mounted the bumper wrong.
Poor attention to detail on the shops end.
Agreed on the attention to detail. It's quite obvious now there's an issue with how the bumper was cut.
Thanks for the info everyone - got in contact with ARB to write the shop on how it's supposed to look.
You very welcome [emoji482]
The Stedi outside rings...middle of the afternoon, sorry.
Ome887?
OME heavy front medium back and summit bumper.
Are you running OME 887 front? if so, do you mind measuring from the center wheel hub to the lower part of the fender.
I have ome 885, installed the bumber and winch, and it went down a lot. Trying to figure out if 887 will be enough.
Man I usually love ARB bull bars. We've put them on a 3rd gen, 4th gen and GX470 and all complement the look so well. I just cannot get behind this one.
Ok so haven’t spent the time to install the turn signals, but can anyone take a picture of where they spliced into the turn signal wires? I can’t seem to find the right wires
Does anyone have a close-up of the side showing the gap between the ARB and the OEM bumper?
I had the ARB off a few days ago to see what the issue was and mine was sitting right on top of bracket holding the OEM part of the bumper - and now it's all sorts of messed up now. The ARB was pressed so tight against that bracket, it had to be trimmed back.
Sent from my Pixel 4 XL using Tapatalk
Anyone their LED indicator light just die? My passenger side died. Wiring looks fine. The white marker light works, but the indicator light no longer works on one side.
Anyone mounted a 12k winch on this one? I have badlands Apex which, I understand, is the same size as warn zeon 12-s. Just trying to see if any issues.
I just read the max size is 10k Lbs but its worth the try.
Post pics if you get it done :thumb3:
Hello all, from three years into the future. Getting ready to order my Summit, but very curious if anyone is running an RCI skidplate with this bumper. I want to see if they interfere or if they can be mounted together without issues. ARB nor RCI can confirm.
Hi, did you ever get the bumper and try the RCI front skid? :banana:
