whos looking to have Fluid film undercoating!!!
If anyone in the NJ area is looking to have their car fluid film undercoated let me know as i can do it for you for a lot less then what some of these shops are asking, as i have access to lifts all being sprayed with professional sprayer for a thick coating. Hit me up if you are interested
If anyone in the NJ area is looking to have their car fluid film undercoated let me know as i can do it for you for a lot less then what some of these shops are asking, as i have access to lifts etc. Hit me up if you are interested
Where in NJ are you?
I did mine in my garage with the car on the ground. I wish someone in KC offered this as a service as it was really messy. Although we don't get a ton of salt put down like you guys do on the east coast.
FYI for those DIYing it: the stuff in the aerosol cans is much thinner (drippier) than the stuff in the paint cans (doesn't drip unless you put in on really thick, or you get very hot weather immediately after applying). If you have a sprayer that can spray the thick stuff, you shouldn't get drips.
Yup you are absolutely right. The spray cans are very thin. For the best protection it needs to be sprayed on thick with a sprayer. The cans are good for small area like latches lower door parts, hinges etc.
Thanks to all of you so far who i have taken care of, now your fully protected for winter!
Message me to setup to have your car done!
just a few pics after the first coat
as i do a few good coats to make sure everything is fully covered and protected
Can you update these pictures with a different host? I'm curious how a professional job looks versus the rattle can jobs I have been doing on mine the last few years.
you know of any other free hosts i can use? or pm me your cell and i will text you pics. photobucket sucks
the rattle can jobs wont compare, as they are a lot more runny. the professional sprayer with the gallon allows you to put a thick heavy coat on and use the attachments to get inside the frame rails and other tight spraying areas withe the 360 deg sprayer. dont get me wrong rattle cans are ok but just not getting that thick coverage.
Got this done today. Thanks op
ghengiskhan
