RUSTED Rear Gate Glass lift mechanism - Help
niadh0
so my 2010 LE rear lift gate had lots of small things rattling inside. plus every time i go for a car wash or heavy rain, the rear lift gate would collect water, and then later drain from the holes and handle area when the door is opened or closed. so i open the panels and found that the rear window lift mechanism/sub-assembly was 100% rusted. the window motor was some how hanging on the wires. so i ordered a full replacement and replaced it today. Unfortunately it did not work 100%. the rust really got on all the screws of assembly.
the factory back glass comes with attached plastic adapters with embedded metal nut inside, that helps the glass sit on the sub-assembly. and two bolts then secure the glass (via the adapters) to the sub-assembly. these two bolts were mostly rusted and the metal nut inside the plastic adapter were 100% rusted - seized completely. all four plastic adapters attached to the rear glass BROKE.
do you know if I have to replace the full glass or can i find these plastic clips/adapters anywhere (to replace the broken ones)?
Got an answer to my own question.
Amazon has it all. just ordered part "Bross BWR5033" to replace the clips. I don't think that Toyota sell this part separately.
https://www.amazon.ca/Bross-BWR5033...&qid=1526254352&sr=1-1&keywords=Bross+BWR5033
Not to be a Mooch, but its my turn now.... Track is rusted and the clips busted right away.
Were these clips the right size? I noticed that there are a few different ones that Bross Made. What did you use to glue them?
Thanks,
JP
yes these clips fit fine.
i used Black Automotive Adhesive that they used for Glass Windows - Polyurethane. Worked fine and still holds it well.
I had to open it all again recently because the window motor i re-used stopped working. Bought a new one and replaced it. when you do this, make sure to give a good spray of FluidFilm on the new mechanism and the motor. 5th Gen 4R rear gate has a design issue... water somehow gets in it and start rusting the stuff inside. so many people have this issue.
Permatex Polyurethane Black Adhesive, 80-mL | Canadian Tire
Fluid Film Rust & Corrosion Prevention | Canadian Tire
Thanks,
JP
My mechanism was super rusted too. I grinder it all down and luckily my rollers were still intact. Nice find. I bet some skateboard bearings would work
I just got back after getting mine repaired somewhat. The window regulator had rusted and chunks were falling off it! I need to get the tailgate rust repaired by the trim through the warranty. Even though the regulator was busted and loose on one side - the window still worked like a charm no issues; Till I got it back from the rust repair. The whole thing was collapsed! I had the new regulator put in but when the repair guy went to loosen up the window bolts 2 of the glass mounts broke... #$#%^&##$$%!!!!
Thanks for the info regarding new mounts. I am ordering them now... not gonna pay 500/CAD for new glass!
