Anyone know how to remove wiper arms and cowl??
TRDpro4R
As title states, anyone know how to remove the wipe arms specifically? I got the cover off and the nut off but something else is holding it in place. I am trying to remove the cowl. Thanks
If I understand your question correctly, you removed the plastic cap and the nut that holds your wiper arm. Your wiper still feels firmly planted, correct? If so, I found it easy to simply fold up the wiper arm like when you wash your car. When I did this, the tension went away and my wipers easily pulled off. Pulling the cowl from here is simple. Pop the corner covers at the base of your windshield. Then release the two push pin fasteners on either side. Then carefully unlock the clips along the length of the cowl on the underside. You’ll see them when you get there. You can pretty much just pull the cowl off and away from the windshield but I’d work with a little more care to preserve the clips.
Yeah sounds like you need to get the tension off. Make sure you mark or line the bottom of the wiper with masking tape so you can keep the wipers in the right position.
I’ve found that pushing hard on the bottom section against the hinge also does the trick. It’ll pop off right away and you should feel the tension no longer there.
Folding up the wiper arm to release the tension did the trick. Thanks!
youngrk
