Expedition One Rear Bumper
onepremiere
I wanted to share some info and photos of the Expedition One Rear Bumper I recently installed on the 4Runner. Prior to the install, there wasn’t much info out there on this bumper, so I want to share my experience.
There are a few companies making rear bumpers for the 4Runner, all of which are of great choices. There are a few things that pulled me towards the Expo-One.
1. Retains the factory hitch - Yes, I realize that other bumpers have built in receivers and I fully capable of towing, however, something about the Toyota designed/engineered tow hitch kept me from removing it. Am I towing anything at the moment? Nope. There's always the "what-if".
2. Equal Length Dual Swing Outs - I have a few other plans for the rear set-up, other than what you see here. I really like the equal length arms because they are so modular. There's a lot you can do with this style of set-up. Yeah it takes 10 seconds longer to open a second arm when you need access to the hatch, but it's 10 seconds.
3. OEM Look - Since I color matched my bumper to the body, it's hardly noticeable unless you know what you're looking at. The lines follow the factory bumper so well, it's literally molded into the rear of the truck.
Impressions:
Holy armor batman. This bumper is beefy, and with all that beef comes some weight. You can really see the structural strength of this bumper when you see it off the truck. All of the laser cuts are so clean, it looks like a production line piece. It's hardly noticeable that anyone actually touched this thing by hand. It's extremely apparent someone spent a lot of time engineering this bumper. The next thing I noticed was the swing arm pivot spindles. They use a 1" bearing and seal to keep the elements out. The swing arms have quite a few bends and angles to follow the body lines, a lot of attention to detail. The swing arm latches are really cool. Again, someone took the time to design and build something functional. Not only does the latch keep the swing arm tight, and snug against the bumper, the latch locks the latch handle into place so there is no way for the swing arm to open.
Fit:
Install took a full day. (With proper safety and lunch breaks) The fit is incredible. When I say it fit like a glove. It fit like a glove. Everything lined up perfectly. The bumper actually rests on brackets that are attached to the ends of the frame horns. It’s a really smart design especially for if you are installing the bumper solo, without means of lifting the bumper. Once the bumper is resting on the frame horns, you can check the fit, make any adjustments then tighten it down.
Bottom line, this bumper is legitimate. I don’t think it gets the love it deserves.
That thing looks fantastic! I had a Expedition One front bumper on my 2010 FJ Trail Teams and my experience then mirrored your own now. They build top-quality equipment and the attention to detail is amazing.
I'll definitely have this in mind when it comes time to put a rear bumper on our 4Runner!
Excellent work on taking the pictures!
I have been eyeing this one too for a while. Did you get it on the GB?
Also how hard was the install? Did it involve grinding/cutting etc?
Only cutting you are doing is to the factory bumper. What I did was I found a Super White Rear Bumper on eBay off a wrecked 4Runner. $150 shipped. So I still have the complete factory bumper in the rafters. Install is straight forward, very easy. The whole design is well thought out down to the install.
It was literally, 1. Cut the bumper. 2. Install the brackets. 3. Slide the bumper on. 4. Tighten. 5. Beer.
I would like to see a pic. of how it looks against the rear side panel.
https://i.imgur.com/3NenodQ.jpg
Like this, only pointing down to see the reveal next to the panel.
No problem, I will get those for you. It was a nice day when I shot these photos, so I got distracted by the target rich environment and deviated from the end goal.
That really looks great - and great job on the color match. Did you have it painted locally? Do you mind me asking how much the paint job was?
I've been eyeing up the single arm model, as I use my ladder quite a bit, and am not a fan of their ladder. I'd love to get the dual swing arm and modify the second arm to fit... but who wants to cut up a $$$$$$ new bumper?!
Best latch design in the business. I've been considering their products for my other vehicle as well, some design issues and poor CS have given me pause, but I am still considering it.
I think this is what you’re after.
As you can see I chopped up the rear mud flap to fill the gap. I have some poly rubber that I am trying to make some mud flaps out of. Just having trouble coming up with a mounting solution with out putting holes in the new bumper.
I too have been trying to find a solution to the gap where the mud flaps use to be located. Thanks for the giving me another idea.
really disappointed they didn't incorporate the hitch to improve departure angle
The factory receiver is 4 bolts, if you're not using it, remove it. FYI the exhaust hangs just as low. So you'll have to cut that too. If that doesn't solve the issue, buy a Jeep. For me, departure angle wasn't important, design, fit and function were. It's a killer bumper don't get hung up on departure angle you may never need. If I drag that receiver across some rocks guess what, it just saved the powder coat. Lol.
That looks fantastic! What are doing to make the back-up camera usable?
thanks,
Mike
The old over the shoulder and mirror technique. Haven't started messing with that just yet. I have a few ideas, borrowing some jeep accessories I think I've got a solution. Stay tuned.
$250 for powder coating. I did two colors Appliance White and Satin Black for the mounting brackets.
I know a lot of people are turned away by the incompatibility of the Gobi Ladder which honestly blows my mind. And the fact that people would modify the bumper before the ladder. I thought about this a lot. Ladder $250 vs. Bumper $2000. If I really wanted the Gobi ladder, I would just cut the last 2 feet of the ladder and replace it with straight tube. That would give you the clearance you need to clear the arms. Accessing the roof rack by climbing on top of the spare tire isn't an issue, but I am also 6'3". Just my $.02.
I've heard some really nasty things about this bumper/company from a few people, but coincidentally they're all posting in another company's thread....
Unfortunately I dont think these swing arms work with a Gobi ladder... Unless I'm completely mistaken?
I was unaware of the customer service issues. I had a great experience. Took some time to get the bumper, but when I got it I understood why. Ill be honest, only issue I had was with the shipping carrier. When it showed up, the shipment was trashed, and I mean trashed. Like it had fallen from 6 feet in the air. I have experience shipping very heavy items all over the world and I've never see anything this bad. Thankfully everything was in good shape, and it was just some torn up cardboard.
Ill have to look into these CS issues. Like I said above, I had a good experience.
My advice. Don't be a sheep. I don't let anyone's experience or opinion sway me. If it's something I know is good just by looking at it, and something I want, I'll pull the trigger, regardless of what others have said. If I have a bad experience, well then I had a bad experience. I knew what I was after, and this bumper checked those boxes. End result, very happy.
I totally understand where you're coming from though. It's a big purchase, no one wants to flush that money down the toilet. Wait a few months to be totally unhappy. Totally get it. Us Toyota owners have expectations to the moon. Totally fine, that makes the aftermarket parts that much better, because the bar is set high.
Nice, looks great! Figured it was paint not PC, pretty damn close color match.
I was looking at the single arm. Don't really need the Jerry can mount, and I much prefer my Gobi ladder. I use it a fair amount! If I were to do the dual swing out, I'd modify the arm, not the bumper. I have access to welding and fab equipment, so it doesn't sound tooooo serious. Famous last words, right?
If you notched out the arms for the ladder, that would work. Actually a really good idea. Something I didn't think about.
Already sold my ladder... Dammitttt
Man now that I think about it more, you could literally hole saw tops and the bottoms of the arms to allow clearance on the legs of the ladder. Freaking genius.
I have the front of my T4R the way I want it, but the rear still needs a little upgrading.
Beautifully done - now I have bumper envy.
Question though, can you remove the swing out arms "easily" when you are using the T4R in a daily driver situation? I have been looking at this bumper, but after I installed cabinets in my garage, my T4R would not fit with the spare coming off the bumper.
erinobr2000
