OE Crossbars Useless on 2018 TRD Pro Factory Roof Rack....
jcage89
OK, I know there's a gazillion roof rack threads and this has all been said before, but today I saw it for myself. I have a Yakima Skybox pro that we use for road trips and it worked just fine on my 2006 $runner Sport with factory rack a crossbars. On my '06 I could throw the Skybox up there and load it with a 100+ pounds of vacation stuff and no problemo. The crossbars on my '06 showed no signs of flexing whatsoever.
OK fast forward to my beautiful brand new 2018 TRD pro. I put the skybox on the crossbars and they flex under the weight of the EMPTY Skybox so badly that the cleats on the skybox contact the roof of my rig! Did I mention that was with the empty Skybox? Standing on a ladder if I press some of my weight down into the floor of the box its even worse so I imagine loaded with water and chairs, such on bumpy roads my roof would be at least scratched up if not dented from the skybox, so that was a couple hundred extra bucks wasted.
So - I need to use my Skybox and I am not ready to completely replace the factory rack (budget and sheepish about unbolting those anchors points leaving the possibility leakage into the chassis) Suffice to say although a complete replacement is ideal, I won't be doing that yet.
That being the case, can anyone recommend a good set of aftermarket crossbar that affix to the OE side rails and are rigid to carry the weight of the skybox, low profile and aero as possible? First hand experience and picture would be much appreciated as I have some shopping to do.
Cheers!
JC
Yakima TimberlineTowers and Jetstream Crossbars or get the Thules version.
They use the OEM roof rails but much sturdier crossbars. Many people complain about how the OEM crossbars are just too close to the roof
They are truly awful. I gave mine away on CraigsList. I have a Skybox as well and wonder if the cleats on it would wrap around the LFD Ruggedized crossbars okay? They're awesome and go right into the OE side rails.
Yes those look more rigid but the spade of the LFD appears too squared off or boxy to allow the skybox cleats to wrap around them. You almost need an aero oval shape (or tube) for the cleats to grab. Might be worth contacting LFD though to ask if they are compatible.
I figured it would have to be something like this, but while the cross bars are probably more sturdy, these options lift the crossbars over the top of the OE roof rails so the seems like the skybox would sit really high off the roof and make for more drag and kill mileage. Hope to know someone who has tried it.
JC
Please share pics and feedback when you put them on. Do you have a skybox or something like it?
I still need to get mine powered as I opted LFD not to so it may be a few weeks. I plan on running my Tepui Ayer 2. Also, I have a 13' Trail so my crossbars will be different from the later 5th gens
Lfd
I installed mine last week and they are very strong with minimum flex standing on them. These are the same bars used on their full rack. They can be removed or installed in just a few minutes.
Hey guys,
We don't have any firsthand experience with the Yakima products, but I know a few customers have used our crossbars with Yakima and Thule accessories, including storage boxes.
If you want to give it a try and it doesn't work, just let us know, we'll work with you on it!
Thanks for sharing picrues. I really like these but it further confirms my suspicion that my aero shaped Yakima Skybox cleats will not grab around the more boxy square-ish shape of these LFD bars. Anyway I emailed the LFD people and we'll see what they say. Thanks again for sharing!
Hey guys,
I'm in! Please use me as a test case. I just emailed you.
PS - Off Topic but how did you get rack rails black? Paint them yourself or buy them somewhere?
I'm currently using the LFD crossbars w/ my thule cargo box. The box is a little bit older so it uses the sandwich style mounts versus the newer clamps that Thule/Yakima seem to be using.
My previous setup was yakima cross bars with their mounts that attach to the stock rails. Those would probably work better for the newer style clamps. I prefer the LFD crossbars because they sit slightly lower than my yakima setup.
This is exactly what I want mine to look like - but yes mine has the newer style aero-shaped cleats for mounting. We'll see if I can work out something to try it out and then I'll be happy to share with all the outcome.
I bought the LFD crossbars for just the same reason. I have a newer Thule box and the clamps grip the new crossbars just fine. Drove 2K miles with no issues at all.
I would very much appreciate if you had a picture somewhere showing the skybox clamps around the LFD bars (I know that's not likely) and if not I would appreciate even more if you are willing to throw it up there and take a detail picture so I can see if it's like my Yakima Skybox Pro (I know that's a pain to do so I feel bad for asking but would be awesome to see it!).
Thanks
JC
You could always easily change the mounting style of them and just bolt/washer/nut through the new cross bars to hold the rack down. Or take the bolts that come with the clamps to a good bolt shop and get longer ones.
Removed and sold my Gobi to go back to stock rack. Had my side rails powder coated black and bought the LFD cross bars. Works great for my Thule box. The stock cross bars are a joke. My Thule would rub the roof up front using the stock cross bars. Haul kayaks up there too with kayak racks too. Works great.
Rialm
