Quick Fist Mounts
JKRunner
Not sure if this is the right section on the forum to post this question but, Can anyone post up some pictures or tell me how to mount Quick Fist Mount’s on my Modular Storage Panel?
Thanks in advance.
The quickfist has a hole in the middle that you can bolt on to most storage panels. What storage panels did you go with?
Not familiar with that brand. But if they have holes in the middle of the molle slots, you just bolt the quick fist on.
Never heard of Orange Boxx either but just looked them up. Each panel has all those little circular holes between each rectangular cut out. Bolt the quickfist to that.
The quickfist uses a #10 bolt. Go down to your local hardware store and grab some number #10 x 1-1/2" Flat Machine Screw with nylock nuts and washers (you don't have to use Nylock but I prefer nylock so they don't back out from vibration). Stick a closed end wrench through the panel and use it to hold the nut while you use a philips screwdriver to tighten down the quickfists. It can be a pain and takes a little bit of time since you don't have a lot of space to work with.
https://www.lowes.com/pd/Hillman-10...ve-Zinc-Plated-Machine-Screws-6-Count/3036838
