Winter tires for my 2019 4 runner limited?
4runnerinbc
Decided I will need better tires for the winter
I initially thought the factory ones would be ok for a year or 2
Now I do not think so
The factory size is 245-/60R
Kal tire, a popular franchise here in canada, does not even list a winter or a four season tire in that size
Do not need off road or mud tires
What to do?
Ive never searched for limited tires - there isnt much appealing out there
My person recommendation. Buy new cheap wheels and run a more common size all terrain like K02 etc.
What to do?
I ran winters for the last two seasons. My recommendation is buying a cheap set of 17" wheels, another set of pressure sensors and get 265/70/17s in any winter tire you can. I had great luck with Winterforce 2 UVs.
Note that every season you will have to switch tires onto your wheels if you only have one set or wheels / tpms. If you have two sets you just take them in and have the pressure sensors synced up each year.
If you do not plan on swapping out those tires during the summer months, get a regular tire with a snowflake rating. I'd probably keep the factor ones until they wear out unless you will be driving up the Whistler alot or other mountain roads.
Thanks for the answer.
But as I only drive 8000 to 10000 miles per year just too long to wait.
I have not yet found a 4 season snow flake rated tire.
Will need to keep looking...
What you need is a tire with 3PMSF rating. It is not a true winter tire, but it is better than a regular all terrain tire.
Here is an example.
There is a link describing what 3PMSF is in the tire description but you can also click here.
The Duratrac's also have the advantage of a strong sidewall which will provide protection against sidewall intrusions that you may encounter on some 4x4 roads or even rough 4x2 roads.
“All Weather” tires are significantly better than all terrain or all season tires for winter, but a dedicated winter tire (Hakkapellittas or Bliazzaks) are your best bet.
While I have an SR5, I'm ordering a set of Cooper Discoverer AT3 4S in the next couple weeks and these will be my year-round tires. The factory Bridgestones that came with the truck were absolutely scary on icy roads last spring (I bought the truck used in early April) as we had a couple of late winter snow blasts. I've run the Discoverer AT3 tires on my last couple of Land Rovers and found them solid and long-wearing. The 4S have the snow rating and this also gives me an extra insurance discount in Ontario.
This.
For the price of good winter 20's you can get 17'"rims and even better winter tires. I did this for my wife's edge that has 20's.
There's a blizzak in that size. You might have to try some different widths, or go with a dedicated 17" rim for your winter tires.... that will really open the options up, and you'll be thankful every fall and springtime when its time to swap.
Also, check out PMC tire. Best prices in Canada that I've found. I got free shipping, and they arrived in 2 days. And I live in the whillywhacks.
Find cheap tires online, all the best brands on sale! - PMCtire Canada
Exactly. I'm not a winter tire person, and I don't know what shops and tires are available in CA, but I've read tons of people who love the Blizzaks. Here they are exactly in that size.
Apparently these are 3PMSF
"The Blizzak DM-V2 radial meets the industry's severe snow service requirements and is branded with the three-peak mountain snowflake (3PMSF) symbol. NOTE: The first 55% of the Blizzak DM-V2's tread depth features the NanoPro Tech Multicell Compound while the remaining 45% features a standard winter tire compound."
Apparently that's good enough for British Columbia:
"What is a Legal Winter Tire in B.C.?
A legal winter tire (on a standard passenger vehicle or a four-wheel/all-wheel vehicle) MUST have at least 3.5 mm of tread depth.
A winter tire must be labelled with either of the following:
The letters "M" and "S", the minimum legal requirement (mud + snow/all season tires)
The 3-peaked mountain and snowflake symbol (ome manufacturers label with both the mountain snowflake and the M+S symbol)"
I have 3 sets of tires for winter ,summer and overlanding and I bought Nokian Hakkapeliittas R3 with trd Pro wheels for winter.
I live in Ontario and have been using Goodyear Wrangler Duratracs the last 3 winters and have been using the tires all year round. Zero issues even with the winter we had last year. 275/55/20.
275/55/R20 will fit the limited wheels and opens up more options for you like Nokian Hakka 9s and R3s.
Well yeah, but now you've gone to a way wider tire which is exactly the opposite of what you want for snow tires.
I like the 17" wheel option. Though then you can't brag about your dubs.
Less than half an inch wider than stock 17s and a true winter tire will be far better than an AT tire with the 3PMSF.
I turned my limited 20s in to winter wheels and got a set of 17s with AT Tires for Spring, Summer, and Fall.
After running two Canadian winters on my Michelin Premier LTX 245/60R20 Michelin Premier all-season tires (20" Limited rims), I began searching for a second set of OEM alloy rims last summer (2018) to run a set of dedicated winters.
I found some 2018 TRD Off-Road take-off rims with very low mileage at a reasonable price, and then installed Toyo Observe GSi-5 265/70R17 winter tires. Fit perfectly on my 2011 Limited.
The Toyos did a very good job up here in Northern Ontario.
Having a second set of rims removes some of the hassle associated with the seasonal changeovers with only one set of rims. The winter rims may take a beating (corrosion!) if road salt is used on your roads. That is why I decided not to run steelies - they rust far too quickly up here.
seltzernator
