Help me locate the squeak/noise from rear
supermark
Noticed I had this horrible noise lately, vehicle just clocked 30k miles and its a 2021 with kdss. It only squeak when mildly hard accelerate or braking. dead quiet on the road, over bump, uneven surfaces...I have tried lube up every control arm, track bar joints, kdss bushing, spring pocket, and the parking brake bracket..Removed everything in the vehicle, fold down the back seats....I even took the shocks off and it still has it. Guys I'm really running out of ideas...
It's quiet even I jump on the back of the vehicle, so may be the brakes??
trying to locate the squeaking - YouTube
https://www.youtube.com/watch?v=V14sief5F9k&feature=youtu.be
What did you do to make it squeak in the first video? Have someone do the same thing while you touch a screwdriver to various components to find a point where you feel the most vibration in your hand. Alternatively, you may use a mechanics stethoscope or a short length of pipe to locate the squeak. Hold one end of pipe to your ear and position other end near various locations searching for the loudest point of noise.
just touching gas and stepping on the brake. Weird thing is no matter how hard I rock the vehicle it’s dead quiet.
I had a similar issue on my 2014. It happened when I had the second row seat either all the way forward or back can't recall. Just leaving it somewhere in the middle resolved it.
You could also make sure the tools and tire jack aren't rattling inside the rear compartment if you haven't already....
