Old 04-07-2023, 09:17 PM #31
scfw0x0f scfw0x0f is offline
scfw0x0f is on a distinguished road
That all sounds great but I'd rather have an over-spec alternator than have to monitor alternator temperatures personally, or chance losing charging capacity due to an overload. A 60A fuse only means that the wiring is expected to handle more than 60A, and the load is expected to draw less; it doesn't really indicate actual load. I would expect 40A out, same voltage in and out, would draw 42A to 44A for a reasonably efficient regulator.
I think the inverter power being derated by Toyota from 400W (in park) to 100W (in drive) is indicative of how much (or little) power is available from the alternator. I agree, in a lot of cases the stock alternator is probably fine for this application. I'm still going to hold out for the DC Power alternator, just because I want the extra capacity, and may add more loads later.
Thanks for sharing your solution. It sounds very useful for a lot of users.
scfw0x0f is offline   Reply With QuoteReply With Quote
Old 04-07-2023, 11:38 PM #32
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
I think I dropped in on this thread after you already made your decision, but I had a question for my own learning.
You say “rather have an over spec alternator than have to monitor alternator temperatures”.
Would the heat build in the alternator (vs the wires, if the wires were not insufficient) in the case that the charging rate of your system exceeded the available current of the stock alternator? Would there just be a voltage drop? Both?
If there are options for multiple alternators on the 4Runner, I’ve toyed with the idea of having one be a 24V alternator (seen some up to 150A) to charge accessory batteries more efficiently.
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 04-08-2023, 12:31 AM #33
Interesting questions and options!
24V alternator: I'd be interested in this, but given the problems fitting a new higher-capacity alternator, I suspect adding a second alternator would be crazy hard. I don't want to add a 24V-12V DC/DC for the rest of the electronics, change to a 24V starter, etc. This could be a great option at home, on a boat, or in a larger vehicle.
The available current from the stock alternator, after subtracting loads for the stock devices, is an open question. I regard the information that Toyota restricts the load on the stock inverter to 100W when driving, but allows 400W when in park, to indicate that the available current may be pretty low (100W) in some cases. Toyota almost certainly built in margin on that, but I suspect it's not more than 100%, so 200W max when driving. Several things could happen:
* The voltage from the alternator could drop so low that the starter battery might start to supply current, which would be Bad (draining the starter battery).
* The big 140A fuse that protects the alternator and its wiring could open. Replacing it is a PITA.
* The alternator could overheat if not monitored (hot day, slow speed, high load).
In general, running electronics below their ratings (usually power, but also temps, and depth of discharge and peak charge level for some batteries) prolongs the life of the electronics. Electromechanical devices like alternators also generally benefit from lower loading. A nominal 270 amp alternator that can maintain that output at a certain ambient temperature, should be a lot cooler and last longer than a 130 amp alternator for the same output, all other factors being equal (no fair comparing an oil-cooled device against an air-cooled one, for example).
@4RExplorer 's approach is perfectly valid in a "let's see what works" approach to the problem. But as he's said, he's be careful about what he runs when charging; I'd rather not have to track alternator temps, or chance losing charging capacity even with an automatic system to watch the alternator temperatures and output current.
Does that help or did I go sideways on your question?
Old 04-08-2023, 08:52 AM #34
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
@4RExplorer
@scfw0x0f
@2021nightshade4x4
Not sure if you missed it earlier in this thread..but I did just install the DC power alternator....and it works great.
Here is the install thread
High Power Alternator install
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 04-08-2023, 11:46 AM #35
Originally Posted by lewdog998 View Post
@4RExplorer
@scfw0x0f
@2021nightshade4x4
Yes, and thanks for breaking that trail! I’m holding off until @DCPower_Anthony issues official instructions; my mechanic is more likely to be willing to work from those than from a post here. I do electrics, mostly, and leave the really funky wrenching to others.
alternator , battery , charging , starter , stock
How much headroom does the stock electrical system have? Nodents2017 5th gen T4Rs 2 04-14-2022 04:19 PM
Excess brake dust... RedMagik 5th gen T4Rs 7 08-29-2015 10:04 AM
Dual batteries. Why do we need it VS a larger high capacity one in stock location? gshadow325 4th Gen T4Rs 17 10-31-2013 02:23 PM
Anybody good with the electrical system moneypit 4th Gen T4Rs 7 07-12-2012 03:08 AM
Any interest in buying my stock exhaust system and/or stock intake system ? DarksideSurf Classifieds - buy & sell (no commercial ads please) 0 01-12-2007 01:30 PM
