OME 2883's with 5100 Front Shocks
jhuerta22
Is anyone running this setup on the front? I bought the 5100's as an upgrade and I'm considering bumping up to the 2nd perch for .85" of lift, but after some reading it sounds like the OME 2883 front coils might net about 1.5" of lift up front and nearly level the truck, which is more for what I'm going for. Did anyone have to run spacers in the rear for a true level with this kind of front setup?
2" in the front makes it about level, so no need to add spacers in the rear unless you want some rake back. I'm not running that OME/5100 setup, but my Fox 2.0s are 2" in the front and it's level without any rear lift.
