02-18-2016, 01:33 AM
![DesertCanyons's Avatar](https://www.toyota-4runner.org/customavatars/avatar115572_1.gif) |
Real Name: Dave
Real Name: Dave
E-Locker and Differential Breather install, Trail Edition
I read several threads on how to install the Scuba Mod for the rear differential and axle. I had to read a lot before I realized there's also a one-way valve for the E-Locker on the Trail Edition that should also be extended up to an elevated valve. This thread is about how I installed an air line from both of these rear differential units to a higher point.
Before I tried this mod I read the many threads about how to install the mod for just the differential/axle. I found them very helpful but limited to the diff/axle breather.
Rear Diff Breather Mod - Complete!
http://www.toyota-4runner.org/1721720-post13.html
And one source for a filtered breather part. This part is too large to fit next to the gas cap. It's often mounted inside the jack tool compartment.
Differential Breather Kit - Raw Mind Engineering
For the top end of the tube I used a Toyota part which looks like it might be a one way valve for one of the breather tubes on the front diff' or transmission, located at the front firewall. The Toyota part number is shown in the photos below. For the connection to the diff' I used the same part recommended in the links above and shown in the photos below. Both parts together cost about $16.
I also bought a set of couplers, a T-coupler, grommets, hose clamps and 1/4" and 5/16" fuel line hose from my local auto parts store, Pep Boys. The connector parts are shown below. I didn't use all of them but did use one of the PVC grommets, a T-coupler and a universal straight coupler. The tube on the breather part doesn't fit in the 1/4" tube so I used a 2nd piece of 5/16" hose.
Before you start, remove the spare tire and the left rear mud guard. Remove the inside edge of the plastic wheel well liner so it can be bent forward and outward. If anyone knows an easy way to pop those plastic body clips please speak up. It would have been easier if I had removed the whole wheel well liner.
See the photos of the OEM one-way valves in place on the differential/axle and the E-Locker. In the photos notice the diff/axle valve, the tube leading from the E-Locker, the E-Locker valve extended to behind a frame cross bar, the parts from Pep Boys and the 2 original one-way valves after they were removed. The threaded valve is from the axle and the one with a small tube fitting is from the end of the small tube from the E-Locker.
Notice that the E-Locker tube runs through a grey plastic electrical bundle protector. The thin tube comes out of that bundle and loops down and then up to the valve behind the frame, which is next to that same bundled wire connector plug.
I've posted more photos in the next few posts. I used a 100 mm macro lens and strobe for these photos which prevented me from taking wide shots of the frame around the parts but I think this lens worked to show most of the parts.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
02-18-2016, 01:40 AM
Real Name: Dave
Real Name: Dave
Routing the diff' and E-Locker breather tube
For the tube location I tried to find the large OEM grommet that everyone else shows. I couldn't see it from the top, inside the jack tool compartment. I think it's hidden below the tool brackets. A couple of people posted pic's of the OEM grommet with crude holes carved in the rubber. At least one person did a better job using a tube to punch the rubber. Given its low, exposed location and the thin, oversized grommet, this install is likely to leak in a deep stream crossing.
I decided to buy a new grommet to fit the hose and drill a new hole in the wheel well where it's higher and easier to access from inside. I found a PVC valve grommet that fit the hose. It is about 3/8" thick and has a wide surface area for resisting leakage. Using an angled drill motor I drilled a hole from inside the tool compartment where the jack is mounted. I drilled a small test hole to verify it was high up in the wheel well area. Then I drilled a 1/2" hole and ground it out farther, to about 5/8", with a drill-mounted, 5/8" tapered cylindrical grinding stone. The grommet fit perfectly and provides more surface area around the hose and against the metal wheel well.
Some of you may find a better place to install a new grommet than up on the wheel well but it's really hard to locate where you're looking from the underside and relate it to where that is inside the tool compartment. If you find a generic PVC grommet verify the diameter of hole you need.
Next I drilled a small hole and located the breather part next to the gas cap, below the latch post. It's more upright here and these work simply by gravity, the weight of the metal cap on a tube end. The photo doesn't show the tube connector end but it fit's a 5//16" fuel line tube. The small connector goes through the body. The tube and clamp are located inside the jack tool compartment. A universal tube connector was placed inside the jack compartment to transition from 5/16" to 1/4" tube. The 1/4" tube goes through the PVC valve grommet. I left a coil of the tube in the tool compartment because, they sold me more than I needed, I have no other use for it and it makes it easier to access the tube later if the connector needs replacing.
02-18-2016, 01:43 AM
![MTN4RNR's Avatar](https://www.toyota-4runner.org/customavatars/avatar129593_1.gif) |
Real Name: Max
Real Name: Max
Nicely done! At least you didn't remove the rear bumper like I did
02-18-2016, 01:49 AM
Real Name: Dave
Real Name: Dave
Running the tube under the frame
3rd and Final Post
Moving away from the jack compartment through the wheel well and PVC valve grommet I routed the 1/4" fuel line tube next to the gas fill tube. I extended the tube to just over the OEM E-Locker valve location, where I installed a T-coupler. I installed the smaller OEM E-Locker tube end to the T and added another section of 1/4" tube extending towards the axle. I looped the tube loosely over the gas fill tube behind the gas tank in 3 big, 6" round loops and connected it to the Toyota union on the diff/'axle.
Where the T sits next to the E-Locker connection plug I wrapped the hose clamp with electrical tape so it won't wear on the wires or cause a short later, as the car moves.
I used plastic wire ties (orange) to keep the 1/4" tube in place everywhere except over the axle, where it must move freely as the axle moves up and down. I have three loops of hose over the fuel pipe so it has plenty of slack to take up as the axle shifts. Using two ties I tied the T-coupler to the shiny metal plate on top of the frame, under the E-Locker bundled wire connection mount. These 2 anchor ties are not visible in the photos.
I believe this solution to the E-Locker and Differential/axle breather install is better and easier than the threads I've read, linked above. The holes in the metal body work were easy to access. The PVC valve grommet is a better seal than the OEM grommet which sits lower, behind the wheel well. If the OEM grommet leaks I don't think you can see that because it sits below the tool brackets. Routing the 1/4" tube was easy and direct, following the fuel filler tube. There's no pressure in the system since it's open all the time. The OEM E-Locker one-way valve was merely slipped inside the thin grey tube without a hose clamp. This solution works and after seeing what Toyota installed, it's much safer for protecting your expensive drive train from water intrusion.
02-18-2016, 02:06 AM
Real Name: Dave
Real Name: Dave
Originally Posted by MTN4RNR
Nicely done! At least you didn't remove the rear bumper like I did ![Whoo](https://www.toyota-4runner.org/images/smilies/whoo.gif)
Too funny! I would have never tried this mod if I thought I had to remove the back bumper. Body work is not my forte.
02-18-2016, 02:54 AM
Don't forget that the whole point of relocating the breather is so you can get rid of those valves and use a filter instead.
2010 Trail w/KDSS
1997 Limited w/locker: sold
02-18-2016, 03:52 AM
![Saker's Avatar](https://www.toyota-4runner.org/customavatars/avatar103267_1.gif) |
@ DesertCanyons
Very nice write-up with descriptions & on all parts used.
Just as
@ T5RUNNER
, pointed out, you need a filter, not the one way valves.... pressures can equalize continuously!
02-18-2016, 07:48 AM
![Cymon's Avatar](https://www.toyota-4runner.org/customavatars/avatar120701_1.gif) |
Real Name: Chris
Real Name: Chris
Nice write-up! This will be my first mod in a week or two. I'm thinking I'll be lazy and order the ARB kit from Amazon Amazon.com: ARB 170112 Differential Axle Breather: Automotive but then run it up along the electrical sensor wiring along the passenger side up to the engine bay. I know it's more $ then I need to spend to get the same result but it will be time saved shopping and waiting for parts. Thanks Prime!
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
02-18-2016, 10:05 AM
![codyHTX's Avatar](https://www.toyota-4runner.org/customavatars/avatar127657_1.gif) |
@ DesertCanyons
thanks for the detailed writeup and pics, i was in the same situation, lots of reading available on the diff breather relocation but not much mention of the E-locker tie-in. this helps a lot
@ T5RUNNER
@ Saker
am i understanding this right, the Breather 90930-03136 is a 1-way valve and not a 2-way breather? this is something i'm still confused on after reading many of these threads.
2015 Trail Premium
SCS/BFG, King/Dobinsons/JBA, Icon/Sonoran Steel, Hefty Fabworks, Shrockworks, RCI, XD HID, Gobi, FJ Toyman, GZila, Dog-Proofed
02-18-2016, 10:50 AM
![wfo9's Avatar](https://www.toyota-4runner.org/customavatars/avatar106176_1.gif) |
Pretty sure he is using the breather part# 90930-03136
It is not one way.. It just has a dust cap... no filter element. Same ones are up front at the top of the drivers fender for the ADD and front diff.... I think.
02-18-2016, 11:39 AM
Real Name: Dave
Real Name: Dave
OEM Toyota "plug, breather" part
@ T5RUNNER
and
@ Saker
Hi and thanks to everyone for questioning how the OEM Toyota "plug, breather" part works. This is a good question.
I saw the filter manifold and photos of how people install them in the jack tool compartment. The only downside is the top of the breather line is inside the truck. If it exhales those fumes are inside. If it malfunctions, and I've seen the GX 470 do this, it can spit oil up and out. Not sure how likely that is? The filter doesn't fit behind the gas cap filler door, AFAIK.
I have assumed the OEM Toyota "plug, breather" part can draw air. Otherwise the diff couldn't equalize the pressure as it cools in your garage. All diff's have an opening somewhere, right? Later today I'll test this with the parts I removed. If it can draw air and exhale air then my assumption is correct. And these are the same breathers Toyota uses in the front.
02-18-2016, 11:45 AM
Real Name: Max
Real Name: Max
Correct. The part that he has (same as what I used) is not a 1-way. It is the same breather used by the front differential, which is a 2 way breather.
02-18-2016, 11:48 AM
Real Name: Max
Real Name: Max
The OEM part that
@ DesertCanyons
used is the same part that is used for the front differential, which is a 2 way breather. The rear OEM breather is one way, as it sits on the axle and is subject to being submerged. The front differential breather from the factory is mounted up on the passenger side firewall and hence is capped with a 2 way breather because it is not in danger of being submerged.
02-18-2016, 11:54 AM
Real Name: Max
Real Name: Max
If you're thinking of running the lines separately, the ARB is probably the best way to go. Looking back now, I should have done it that way. I ran separate lines and had to do some finagling to make it all work together. If you're just running the axle breather, its cheaper to do just the single line with OEM parts. My Toyota dealer had them in stock within 48 hours. Fuel/transmission line and hose clamps are readily available at an auto store.
The breather caps are one way valves, but only work properly when mounted vertically. When your diff cools it draws air in through the axle seals. That's fine in a parking lot, but not so good in a creek crossing. You can by special tiny filters made exactly for this.
2010 Trail w/KDSS
