PLX Devices 2340 KIWI Wifi
DEKA3
Registered User, A.K.A. "elias"
I know that a 3rd gen member has used it last year, but hasn't provided any details on the product and its efficiency.
I am wondering if it can actually help us with diagnosing various aspects like MPG's and the like or is it just a flashy gimmick? I can always go with the cheaper scanmaster units, but this looks a whole lot cooler!
PLX Kiwi Wifi - Connect your iPhone / iPod Touch to your car's OBD2 OBDII Port. and the iPhone software is REV or some others that I cant recall right now, but are on the website attached.
Has anybody on the 5th gen forums used this yet?
I use the Ultragauge and really like it. Its only like $60 and a fun toy to play with.
I think these are the available gauges for the 4Runner.
Available gauges for display.
Protocol: 11-bit CAN
Open/Closed Loop Emissions Status
Percent Engine Load
Engine coolant temperature
Short Term Fuel Trim Bank 1
Long Term Fuel Trim Bank 1
Short Term Fuel Trim Bank 2
Long Term Fuel Trim Bank 2
RPM
MPH
Ignition Timing Advance
Intake Air Temperature
Mass Air Flow Sensor output in grams/sec
Absolute Throttle Position Percentage
Bank 1 Oxygen Sensor 2 Voltage
Bank 2 Oxygen Sensor 2 Voltage
ECM RUN TIME
Distance traveled with Check Engine Light on
Bank 1 Wide Oxygen Sensor 1 lambda Voltage
Bank 2 Wide Oxygen Sensor 1 lambda Voltage
Commanded Evaporative purge Percent
Number of warm-ups Since Check Engine Light cleared
Distance traveled since Check Engine Light cleared
Barometric Pressure (inHg)
Catalytic Converter Bank 1 Sensor 1 Temperature
Catalytic Converter Bank 2 Sensor 1 Temperature
Catalytic Converter Bank 1 Sensor 2 Temperature
Catalytic Converter Bank 2 Sensor 2 Temperature
Battery Voltage
Relative Throttle Position Percentage
Accelerator Position 1 Percentage
Accelerator Position 2 Percentage
Commanded Throttle Position Percentage
Mass Air Flow 2, Calibrated/Calculated
Instantaneous Miles Per Gallon (MPG)
Average Miles Per Gallon (MPG)
Average Miles Per Hour (MPH)
Average Gallon Per Hour (GPH) - general
Run Time - general
Distance - general
Fuel Used - general
Instantaneous Gallons Per Hour (GPH)
Fuel Tank Gallons Remaining
Distance to Empty(DTE)
Time to Empty (TTE)
Average MPH - trip
Average MPG - trip
Fuel Used Gallons- trip
Average Gallon Per Hour (GPH) - trip
Run Time -trip
Distance - trip
Oil Distance
Service Distance
UltraGauge Temperature
Wow. So all of those gauges you mentioned will be displayed on any unit? (Assuming the unit handles the info)
Correct...... That is the list for the Tacoma, I looks like the 4runner has roughly the same availability for gauges
I have it. I like it, but I dont think it will help you with MPG. It basically just reads all the OBDII info off the computer. So if you throw a trouble code, it will tell you what the code is and allow you to reset it. It also reads the computer to allow you to see what the O2 sensors are reading, MAF sensor, etc. etc.
It works very well for what it says it is supposed to do.
BFLAN, is it worth the money? Or will something cheaper work just as well, minus the flashy "GUI"?
I think the Ultraguage that is listed above does exactly the same thing, and is less money. I just bought it because at the time, I had no idea about the Ultraguage and it was actually less money than most scanners that I was looking at.
It is nice because it uses your iphone, so there is not another device laying around your car, but I would try that Ultraguage and see how it works. For that price, you cant really go wrong!
Thats what I thought... Thanks!
I have it. I use it with my torque app on my droid x, works great. If you have an android phone I'd recommend the app as well.
