donnellyshores
To Do (more thorough list below:
-install tachometer, need to purchase and install a voltmeter
-Spare has been obtained, now needs to be mounted
-Re-wire passenger seat: go to Missing Link for bike cable, cable ends, re-wire
-Horn- horn?????????
-4WD indicator light
-Deal with torsion bar lowering
Done:
-new BFG 235/75/15s, on custom 15x8 rims
-alignment, sway bar/tie rod end set replaced, front passenger side (mechanic)
-new radiator & Catalytic Converter (mechanic)
-installed & wired new Kenwood KDC-125 headunit, Pioneer 6.5" 300W speakers, generic 250W amp
-installed & wired new Peak Work Zone 1200W inverter with remote outlet (in dashboard above passenger side speaker)
-installed new (junkyard), double-decker center console with reupholstered arm rest cover
-replaced front brake pads
-replaced windshield wipers (front and back)
-cleaned, sanded, and painted-on bedliner on entire bed
-replaced windshield washer fluid reservoir (junkyard)
-wired new switch for back window
-installed new (junkyard) interior trim around back windows, utility doors in quarter panels, along base of tailgate
-re-glued trim around exterior of front doors, back seat windows
-bought a tricked out vehicle kit, all fitting in a 25 gallon Rubbermaid Roughneck (the usual: tow straps, Viair 90P air compressor, folding army surplus shovel, 25' jumper cables, Lift Mate for Hi-Lift Jack, Off-Road Base for Hi-Lift Jack, large 1.75L bottle of Black Velvet [emergency whiskey], other various and sundry items)
After getting some advice from people and exploring my options a bit in this thread, I decided my new money pit needed it's own build thread.
Here's the story: about a month ago, I bought an '87 22RE with 258,000 for $2500. The body was rough, but tricked out with nerf bars and a lift and big tires. The interior was even worse, just pretty dirty but also lots of elements falling apart- trim pieces, entire panels of the wall, just bare metal (no rugs or mats left) in the back, broken switches and a recently stolen stereo, just a total piece of shit. Under the hood, though, she was solid, with recently replaced just about everything other than the big components. It has 33x12.5 BFG Mud Terrains on it, on 15" custom rims.
My wife was super pissed :gun6::whip:, but I've been trying to win her over. She wanted a good-looking 3rd gen with running boards. Good luck with that for a budget of $3k! I've appeased her by saying that I'd try to make the interior real spiffy, and I'd try to lower the lift a bit (and/or get smaller tires). We are going on a 2-week, 4000 mile roadtrip from the Bay Area, California to Austin and back (via Utah) [map here], and we leave next Friday (03/22). I've been mostly jacking around and certainly spending moenyfor the past 20 days, and have done only menial tasks, for the most part:
-retrieved various trim parts and other miscellany from junkyards
-rewired new switch for back window
-installed new interior trim around back windows, utility doors in quarter panels, along base of tailgate
-bought components for electrical and audio system: Peak Work Zone 1200W inverter, Kenwood KDC-125 headunit, Pioneer 6.5" 300W speakers (wtf, way too much power, might need an amp), SunPro SuperTach
My to-do list is so long it makes me quake in my boots; or rather it makes my wallet quake in its boots. But many things are low-priority and can wait until after the trip. Some things, I'm not so sure of... and could really use some advice on. To whit...
-My right front sway bar is bent and needs to be replaced. When this was pointed out to me, something was muttered about tie-rod ends, about which I know nothing. Are these components likely failing as companions?
-I need an alignment. Bad.
-Would like to lower the lift a bit, but don't have much ability to do so. Will try tweaking down the front torsion bars, anyway, to even out the butt sag.
-Would like to switch down to stock tires (235 BFG AT's on 15" rims), but have been advised that I need to check and see if it's been regeared. I haven't yet done so, because I have neither a jack nor a tachometer. Both are on order. Actually I do have a Hi-Lift jack, but given that I have nerf bars all the way around, I can't get to any frame components to lift it without the Lift Mate, which is on order. If it has been re-geared, my friend has advised me that I could potentially find a front and rear differential that are stock at a junk yard, and that it would be relatively simple to swap out the re-geared differentials. Is this accurate? I would think this would be a complicated procedure.
-Have various interior pieces that either need replacement or just a good solid cleaning. I think the rear quarter panels are the wrong color and would love to locate some gray ones.
-Need to install stereo, speakers, tachometer, need to purchase and install a voltmeter
-The horn still doesn't work, haven't done anything yet, need to get in and check fuses to see if it's an easy fix
-The 4WD indicator, if there is one, isn't working. Need to get into instrument panel to replace bulb. What a pain in the ass. Might skip it.
-Need to reupholster or figure out some other solution for the new double-high center console, and then need to swap it out with the old one.
-The back windshield wiper doesn't go back into it's little housing, and now I think the arm might be jacked. Someone suggested just not using it, an that may be what happens. I understand now why the switch was disconnected when I found it.
-I'm going to use paint-on liner for the back, since it's so gunked up, and then I'll put carpet remnants on top of that.
-This is much longer term, but... the idle gets louder when I release the clutch and am just in neutral. There's a sort of louder, higher-pitched component to the idle sound. This sound also gets louder if you hit the accelerator while in neutral. With the clutch pressed in the sound is not present. Everyone who's heard it has gotten a worried look on their face but no one seems to have any ideas. Any ideas?
I'll continue to edit and update this list. I'm hoping to get most everything here done in the next 9 days. We'll see... certainly anything that involves swapping differentials won't happen- whatever gearing this truck is set up for is how we're driving to Texas.
Anyway I'd appreciate any advice and I'll post pictures as I go along.
Cheers!:drummer::happy:
Done:
