Rear Backrest Latch with Metal Body
RAD4Runner
Hi guys,
Rear backrest latch on my 1986 4Runner has plastic load-bearing body so it finally broke (Left completely broken, Right cracked), so I'm looking for replacement with metal body.
Do you know if a second-gen or third-gen has similar latches I can use?
The most important things are that:
1) It works like a common gate latch with the door "strike" in video / pics.
2) Dimensions of latch body approx. the same so it will mount on side of seat. Placement of mounting bolts no issue; I can always tap new ones.
3) Release mechanism could be either lever as in first-gens or a push/pull button/rod.
I can always rig up the release mechanism.
Dimensions:
DsH7XrFzB8BJCGZNzuBSUpW01gxJfxchoIRhktc09rBzsAtp8hy-3WLkFxmuyI6mTbWayzkvOrdL4X7l6nPJjwrw7POcocQ3O5lev7IyGQLbihoWMtzVoxBDFwyeq06yA38BRBdjgMh-0uJkkJBkZNBrFzjYfavykcErAc3XplczxQajoAFeG6WtOKLlU_iknAfTw6EuJsT9ONjqhGxLNY3js8cinbB7SE--o-exvAlhUC5OQMXg_M1q7zrK-wkb4s2Nxc6148PJwfD4q9jNAHKJUpswBuc6nIWi83Cw5GbifU6HXteoWNGO6_rLJqiLTZehG-qym3jQ_JKVlrxV0rejnTHz7ZYrsxal9Qiz7bnIbxDfywd-KXrzg1ybPMvRg3Hxr31cG95U1oWxoblWWhxUzXp3Q4TSr7pIExqhSfQPNXPGkwzSIBHhmlA8lLefLiiLsNdGjIt2KQ1l-xBrKREfE86k9G86CbYMg0XTRwGKDasTBJ_bB2JnwGUmXSXtD4yDdirNhy38mPCY6hs5PurtiZ0-TEAL3jIBYnTcWEummBxu8gKRJiFrk2oB-JS8Maub-Um2JWq3KsommlOvxpg0zTR8wlV36fJ-B_v7=w1364-h776-no
"Strike"
FVlKEDVyNm_mk9obvuIjGsdY6y1yqXadSQHmRxrzL7Dna5-b6CAYm59yQZheuYWW5dlIbXqmS7Zgdh1nWzpbZuVNUl51sYiKBItwyt7SqzYtHAcfvKCzZhT0WzmfL3eJ7Ld2snA7ZLmesFdc4Eo87gcMHuH74yW94BqfeM05tNDFNN-bFuW-SYPXsA6tDAPTLvZAz5LWza4-G-Uum3qoKRn80dvCcJ5UCl1Vg3U42FXLKp9RliS0q1O5uz97XDb0WO8b28wKXRRDuwstp5Qfzzm8VACa2AC4d97QWMPusRG8rmJqhnQT-BZ7eGDa4kJdAMQtnpgUHznkLmC5VaK6ydOsf7cd65cQ9soGH0KlCLlqDkNiQX_2gexftoZtVERpD54P4lDIYKhN0CW0tZ27qL-6QegsggnfGlWigRpCQ7orCAt4k8yBRjrgL3eFo_rP0fMWTFxj0ndXEGAGZf0cHoM1OpVT56y8EI6WiaqOLtjRGDW_XFNMyLPPdkWhiJJ84NFlXlLdHFuBhujat3rCs02aW5AWJNwKurN5oacZVdp_q_n0ueUaw7cEzxw2JXc4Yin1pOtlaZGU1Ce4elM3OjDGBQxR-fXPFnC4RMXo=w1380-h776-no
seltzernator
