How to open the rear Hatch and fix the Actuator 4th gen 4runner
mastee
Hello All,
After trying all listred methods unsuccessfully to open the rear hatch, this is how I managed to fix it, now it works smooth as butter and hopefully will help others
My 2004 4runner with 270K miles was owned by couple of wilderness guides from Moab, it came caked in sand and mud. The hatch had been stuck for over a year, I had tried the CPU reset, pushing down hard on tailgate while trying to open the damn thing etc etc.
Take the plastic trim, bottom trim, the weather shield off the hatch. From inside spray some penetrating oil on it, with the bottom trim off from inside you should be able to insert a long screwdriver/prybar where the latch mechanism hooks into the locking jab, wiggle around and with some effort the hook should rotate and the tail gate should open, if the latches are gummed up the soft close/open mechanism will not work
I took the actuator off the tail, took off all the old plastic/vinyl coating on the hook, after cleaning the locking hook it should rotate freely, and if rotated it should stay in place, the large lever should be able to open it from the closed position.
Make sure that the green micro switch's metal prong touches the end of the arm of the geared mechanism, it works as an stop mechanism.
If the soft stop mechanism does not work at this point, upon closer inspection you will see that there is a latch inside the rectangular metal housing which contains the hook assembly, however it moves in horizontal orientation in relation to the locking hook, and is parallel to the bottom metal plate of the housing, to visually see it, look at the metal housing containing the locking hook from the top corner, there are gaps along the corners that form the rectangular enclosure containing the hook. It should look like a small metal nub/rod, try to move this small rod back and forth, and ensure that the latch/rod springs back into position when unlocked or the smaller latch handle is pulled upwards , otherwise clean the heck out of it, this should take care of the soft closing of the hatch
I should have taken pictures, ask away if anything is unclear and I will try to take a few pics for better visualization
There is a release bar on the hatch actuator accessible from inside. If actuator motor runs, fails to release from catch, and then reverses to locked position, simply reverse the catch to present clean side to actuator.
Do I need to replace Actuator?
For the first time ever I experienced the tailgate that won't open on my 2005 4Runner. Thankfully found a video that showed that by removing the ECU-b fuse to reset, it will start working again. Problem is, it only works if I don't lock the doors. Pulling the fuse every time I want to unlock my tailgate is a really bad option.
I guess I'll try cleaning the latch, but it seems like ultimately I'll need a new actuator to fix it.
Related condition, I can't roll down/up the rear glass with the key fob or key, but I can form the dashboard. Will I need a switch too?
Any advice?
Any advice?
There are a few things that will stop that from working. I think the latch not playing is one of them. There's also a reset procedure which I think is basically cycling the window all the way down and up a couple times. The way the latch works when the hatch is closed is the motor should pull the door in, it should click/latch, and then the motor releases. You should hear it run twice. If this doesn't happen then there's something wrong with the latch. I have a cheapo Amazon one in my truck, been working fine for a few years now. The thread below is something else to check out.
Rear hatch actuator fix - latch closes, waits 2 sec, finishes cycle and won't open
2001ATL
