Crank pulley bolt
The trick is to put a breaker bar across the frame, disconnect the coil and give a quick jolt from the starter.... For anyone else searching the forum looking for a solution.
I rested the cam gear remover in the harmonic balancer bolt points and then let it push against the frame while I used the breaker bar to bust it loose.
