Shall we Mud DANCE?(This is Japan-style)
RXvedub said:
.....do you have a seperate switch neer the rear fog switch, for the front fog lights? or is the switch on the headlight switch?
Just to be clear for everyone in Japan, in America the fog & headlight switch is attached to the steering column.
BTW, thank you sharivan for the valuable insight you provide.
RXvedub said:
"Crystal clear" <-- saying in america for 'yes'
RXvedub
Thaks your feeling!
Front fog SW with headlight switch steering column...JAPAN-model too,
(Luxury, Thanks your help comment)
Rear fog SW is seperate,
AlexJet said:
Wide Fender. Does it means that Toyota is going to change tire size?
LED Tailights - ??? How they will look like? Are they the same size/shape? Would I be able to exchange my OEM with those ones without drilling hols and etc.?
Projector Low beam. Defenetly will change the look. The question is: what actually the difference beetween normal light system (what we have right now) and projector one? Different Light pattern, wattage, ...?
Please wait for a while,
At least 17mm only of one side becomes large.
It is 35mm on both sides.(1,875mm---->1,910mm)
Tire size???sorry,
Change parts LED Tailights is probably OK,
Projector Headlight install probably OK
but cannot use adjustment axis,
(This projector lights with an adjustment function)
It does not understand yet for details.
Sorry,
Here is "Gallery" thread,
I posted new thread,
http://www.toyota-4runner.org/showthread.php?s=&threadid=11131
Thanks,
