DIY Mods: Post Write-ups HERE
Functional Mods
Things I've done to improve functional items:
BFG A/Tko LT275/70R16 on steel wheels for winter/offroading:
http://www.toyota-4runner.org/showthread.php?s=&threadid=6857
Custom spare winch wrench:
http://www.toyota-4runner.org/showthread.php?s=&threadid=6480
SureDrain SD-3 engine oil drain valve (no link.)
Mobil 1 engine oil (no link; just search.)
Synthetic driveline grease. Mobil 1 for the U-joints.
Avoid Valvoline Durablend moly fortified for the slip yokes in winter climates.
http://www.toyota-4runner.org/showthread.php?s=&threadid=79400
Custom shackle bracket:
http://www.toyota-4runner.org/showthread.php?s=&threadid=9053
Driver's seat cushion "adjustment":
http://www.toyota-4runner.org/showthread.php?s=&threadid=9353
Horn mod:
http://www.toyota-4runner.org/showthread.php?s=&threadid=9296
AirLift 1000 rear spring helper kit:
http://www.toyota-4runner.org/showthread.php?s=&threadid=14181
Mobil 1 synthetic gear oils:
http://www.toyota-4runner.org/showthread.php?s=&threadid=10117
Replacement Michelin Cross-Terrain P265/75R16 tires:
http://www.toyota-4runner.org/showthread.php?s=&threadid=27144
and my analysis of the Doneflop tread:
http://www.toyota-4runner.org/showthread.php?s=&threadid=24484
Polyurethane sway bar bushings:
http://www.toyota-4runner.org/showthread.php?s=&threadid=34115
Cosmetic & Other items
Other things I've done:
Silverstar light bulbs (no link.)
MagnaFlow side exit tip:
http://www.toyota-4runner.org/showthread.php?s=&threadid=2525
Plugged front inner fender holes:
http://www.toyota-4runner.org/showthread.php?s=&threadid=3781
Receiver plug:
http://www.toyota-4runner.org/showthread.php?s=&threadid=19698
Extra emblems (no link; just search.)
Front brake calipers (and pads):
http://www.toyota-4runner.org/showthread.php?s=&threadid=36979
Front brake caliper rebuild:
http://www.toyota-4runner.org/maint...front-brake-caliper-rebuild-stuck-piston.html
Front CV joint boot clamps:
http://www.toyota-4runner.org/showthread.php?s=&threadid=37107
Replacement windshield (post #56 in this thread):
http://www.toyota-4runner.org/showthread.php?s=&threadid=28629
Broken side window:
http://www.toyota-4runner.org/showthread.php?s=&threadid=52437
Leather shift knob. Bought from a member on the forum. Just screws onto threaded shaft (no link.)
Tire repairs:
http://www.toyota-4runner.org/showthread.php?s=&threadid=34857
http://www.toyota-4runner.org/showthread.php?s=&threadid=87206
Panasonic "maintenance free battery" maintenance:
http://www.toyota-4runner.org/showthread.php?s=&threadid=62199
http://www.toyota-4runner.org/general-discussions/39626-06-battery.html
http://www.toyota-4runner.org/engin...-audio-accessories/9515-what-battery-use.html
Replacement 24F CT Eliminator battery:
http://www.toyota-4runner.org/4th-g...till-oem-panasonic-battery-6.html#post1702678
Alternator/Generator repair:
http://www.toyota-4runner.org/4th-g...-removal-assistance-required.html#post1696378
Prodigy trailer brake controller mount (starts at post #21):
http://www.toyota-4runner.org/showthread.php?s=&threadid=79413
Radiator replacement:
http://www.toyota-4runner.org/showthread.php?s=&threadid=88666
OBDII cable and software:
http://www.toyota-4runner.org/showthread.php?s=&threadid=121604
Temorary muffler rear pipe fix:
http://www.toyota-4runner.org/4th-gen-t4rs/173116-temporary-muffler-rear-pipe-fix.html
This is my first (and most dramatic) mod so far:
attachment.php
Does it look OEM?
I have three, but I am going to have to dig (search) and do some more work (pictures and diagrams)
-Horn Mod: took out stock and put in Stebel air horn... I will put pics on here soon
Hella Horn Mod
http://www.toyota-4runner.org/showthread.php?s=&threadid=49593
-Rear Diff breather - on this forum somewhere
-06 JBL headunit in an 05 sport...
http://www.toyota-4runner.org/showthread.php?s=&threadid=23239
Its a long one, but it has alot of detail and links...
http://www.toyota-4runner.org/showthread.php?s=&threadid=26183&highlight=cornfed
one more about cornfed stuff
UPDATE! I FOUND THAT THE LENS WILL TAKE WATER. AS A FIX, I PUT THE SMALL BREATHER CAPS BACK ON AND USED DUCT TAPE TO WRAP AROUND THE PLUG AND THEN WRAPPED DUCT TAPE AROUND THE SOCKET AFTER I PUT IT BACK IN THE LENS. BASICALLY, I WRAPPED THE WHOLE DAMN THING IN DUCT TAPE
my rear bumper lens mod
Valentine One Remote mount
I mounted my V1 remote just under the top of the dash overhang. My wife didn't even notice it.
chasebradshaw
