03-19-2020, 03:00 PM
Floor Jack....what are you using?
In the market for a good quality floor jack for maintenance tasks on the 4Runner. Curious as to what brand/type/capacity rating members here are using and can recommend?
*2017 4R TRD Pro, 01H5 Cement w/ Shrockworks dimpled tread plate sliders, Moroso oil catch-can, black powder-coated roof rails. (summer runner).
*2005 4R Sport Edition w/ Bilstein 5100's, Gen-5 brake upgrade, K&N cold air intake, cabin air intake mod, Falken Wildpeak AT3. (winter runner).
*1965 Pontiac GTO convertible, 4-speed w/tri-power, PHS documented. (born in Freemont CA).
*1962 Chevrolet C-10 (short-step) pickup, 4-speed, survivor. (born in Oakland CA).
03-19-2020, 03:27 PM
I just picked up a 1.5 ton Pittsburg brand (Harbor Freight) for $60. Low profile, quick pump, works great.
Burt
2008 SR5 V6 4WD
1984 1/2 GT350 Mustang
2019 F250 SuperDuty
03-19-2020, 03:53 PM
Real Name: Michael
Real Name: Michael
This one. Great great greattt quality. Well worth the money. Daytona™ Super-Duty Professional Car Jack
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
03-19-2020, 03:59 PM
Originally Posted by That_Titanium_4RNR
This is the correct answer. Essentially a Snap On clone. Picked one up last weekend and wish I had long ago.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
03-19-2020, 04:14 PM
I have the red harbor freight 3 ton low profile jack. They're discontinuing the gray ones so if you can find one, they're cheaper. I'll link some coupons below, be sure to check that site for good coupons there. Definitely don't need the low profile for the 4runner, can save yourself $10 and get the regular one.
The red lp one I have, is $100: Harbor Freight Tools Coupon Database - Free coupons, 25 percent off coupons, toolbox coupons - RAPID PUMP 3 TON STEEL HEAVY DUTY LOW PROFILE FLOOR JACK
and red reg $90: Harbor Freight Tools Coupon Database - Free coupons, 25 percent off coupons, toolbox coupons - RAPID PUMP 3 TON STEEL HEAVY DUTY FLOOR JACK
additional $5 or $10 combinable coupon: http://www.hfcoupons.com/hfweb/big_c...0304081718.jpg
100% get some jack stands too. get the 6 ton they're taller and also more chonky: Harbor Freight Tools Coupon Database - Free coupons, 25 percent off coupons, toolbox coupons - 6 TON HEAVY DUTY STEEL JACK STANDS
Edit: The harbor fright jack stands I had were recalled, so I picked up some double locking ones from Northern Tool. THey have a cross-pin in the teeth for added safety: https://www.northerntool.com/shop/to...6194_200756194
Heres a coupon for the gray lp $80: Harbor Freight Tools Coupon Database - Free coupons, 25 percent off coupons, toolbox coupons - RAPID PUMP 3 TON LOW PROFILE HEAVY DUTY STEEL FLOOR JACK
$5 off a Pittsburgh pro ratchet also a banger: Harbor Freight Tools Coupon Database - Free coupons, percent off coupons, toolbox coupons
Reason: found extra coupon code, HF jack stand recall
03-19-2020, 04:15 PM
I got an orange Daytona 3 ton jack a little while ago. Highly recommended.
2007 V6 Sport Edition
03-19-2020, 06:14 PM
I got an Arcan XL3000 from Costco. 3 ton and works just fine. I’ve seen it as cheap as $90.
03-19-2020, 06:27 PM
Real Name: Derek
Real Name: Derek
...https://www.toyota-4runner.org/general-discussions/272298-hf-3-ton-floor-jack-$79-99-a.html
Geez this is getting painfull.
You can get a 3 ton low-pro Pitsburg HF jack on sale for 80 bucks "on sale".
look for the sales... Pittsburgh Automtive Low Profile Heavy Duty Car Jack
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
03-19-2020, 07:54 PM
I have a 30+ year old Sears Craftsman Professional 3 1/2-ton floor jack that I still use. Similar to the one in this video
Years ago Craftsman (and Sears) sold out and started producing crap, but my 30+ year old 'Professional' designation hand tools (wrenches, screw drivers, sockets, ratchets, et.al.), air tools, bottle jacks, and floor jacks are still going strong - never could afford the professional grade stuff like Snap-On back then.
03-20-2020, 12:25 PM
not quite a floor jack but ......
This is only possible using 4 wheel drive low.
I hope this isn't to far off topic. I have a bad spine and jacking my t4r up is pretty much undoable. however, these give me the capability of doing some maintenance and keeping repair bills down. Lying on my back and doing work is much easier for me. They also allow me to get a little higher in the engine compartment when doing maintenance, I do this by turning one upside down on the other.
They add an additional 4 1/2 inches so my belly will fit and it doesnt seem like a struggle under the vehicle.
I use the rope to drag them so I don't have to carry them.
And no, I am not afraid of them they are very sturdy (please use in gear only with emergency brake on) . And don't forget to move them before backing up to far.
They are glued and screwed.
NATO Seasparrow Mk 57 Mod 2 & 3
2004 4th Gen Sport Edition
03-21-2020, 06:56 PM
Really nice setup for those ramps Seasparrow.
03-22-2020, 10:41 AM
Thanks, cost is about 25 bucks and home depot did the cutting for free (except the angle cut). Obviously you cant do any work with wheels but very easy for everything else as long as people use emergency brake and also do not drive to far forward. It would probably be safer with some sort of 2x4 stop in the front.
03-23-2020, 01:17 PM
daytona jack
Another Daytona jack user here.
I have 3 of them and I can use 2 in the front and 1 under the rear diff to lift my T4R up for tire rotations.
BLACK 2015 TRD PRO - SAFARI SNORKEL - GOBI STEALTH - TREK BOXX
ICON STAGE 7 (700 LB SPRINGS) - 285/75 R17 NITTO TRAIL GRAPPLER
MAGNUSON SUPERCHARGER - URD FUEL & TUNE UPGRADE
DUAL BATTERY - 250 AMP ALTERNATOR - COMEUP 9500 RSI
SCHROCKWORKS BUMPERS, SLIDERS & SKIDS - 4.56 GEARS
03-31-2020, 09:43 PM
Just picked up the yellow Daytona jack last week and it is awesome!
03-31-2020, 09:44 PM
Real Name: Matt
Real Name: Matt
Black Daytona 3ton low profile
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
