09-26-2011, 09:08 AM
Wow... I don't like that! Never thought someone could get in soo easy....
- Sent via Tapatalk for Android
2006 T4R SR5 v8 4wd: Napa Ultra Premium Rotors; Weather Tech liners; AVS Ventshades; Westin Bull Bar; Hydrocarbon Delete; Blackhoused Headlights; Fog Light Mod; Sulfer TSB; Magnaflow 22" Muffler (#12586); Front: Bilstein 5100's set at .85" + Toytec 1" Net "Top1-T" Spacer = 2" total Front Lift; Rear: Cornfed 1" + Air Lift 1000; Plasti-Dip center grill + rear Toyota Emblem; JVC Bluetooth + HD Radio HDR81BT
http://www.toyota-4runner.org/new-me...purchased.html
09-26-2011, 09:40 AM
Thanks I didn't know it was that easy either
06 sr5/fj springs and shocks/daystar budget boost front/fj 1" rear/ sport hood /weather tech digi fit front floor liners/ Firestone destination 265/70/17/Yakima loadwarrior w extension/led upgrade/more to come.
09-26-2011, 09:55 AM
videos follow with straightforward prevention techniques.
09-26-2011, 12:47 PM
Well, i just examined my garage door. At least for my garage, the release handle is flush mounted against the slider...so, there is no gap for any hook to get into. What i did then was to take out the handle at the bottom of the string.
Thoughts? Am i safe?
2024 Tesla Cybertruck Cyberbeast
My 2023 Ford F150 Platinum FX4 Powerboost with 7.2 kW ProPower Onboard
2023 Lexus GX
2024 Subaru Impreza RS
09-26-2011, 03:08 PM
Super Moderator
Super Moderator
I think it depends more on the garage door and the framing around it.
The garage door they did demo on had a weather strip against the top and appears to be a fiberglass door with a metal brace behind it (giving it some flex) that allows the wedge to push at the top edge.
Just like cars, if an intruder wants in bad enough, they're getting in.
'06 Limited V6
Amy's Mom: "Who's that you're talking to?"
Amy: "It's Uneek, spelled in a 'unique' way."
09-26-2011, 03:43 PM
The problem is that even without the weather stipping, the metal on garage doors are flimsy. In addition, from some reading this morning, robbers have now gone with high-powered battery-operated drills...so, they just drill small holes in your garage door and use the hook method (as in video above).
2023 Lexus GX
09-26-2011, 08:23 PM
I looked at my doors and this is actually not plausible the way they showed. They would just break the glass and be in around 3 seconds..!
09-27-2011, 06:46 AM
Wow I had no idea it’s that easy. I will not be sleeping well tonight.
09-27-2011, 01:20 PM
I think so, at least much better than before. But like you and others mentioned nothing is going to stop a determined pro who is willing to either break a window or drill a hole, etc.
I have the other style release in which I needed to cable tie it up so it cannot be moved with a hook/hanger. Also I blacked out the windows with these... Blackout EZ Window Cover. Nice quality for the price and can be easily removed when working in the garage for long periods and you want some natural light.
One thing I often hate about my garage, no door inside the garage to the main house, can be a benefit in a garage break-in of these sorts.
09-27-2011, 01:54 PM
Although i agree that an experienced thief can get into anything, i also do not want to hand it to them on a silver platter!!  In addition, with desparate times, we're going to see more amateur theives/highschool punks trying to break into homes/cars. So, every little thing helps IMO.
In fact, over the next few weeks, we're getting a metal front door with glass and iron bars. No, it is not those "in-the-hood" type doors. It is something like this:
Basically, it is a steel door with iron bars in front (in any design you want). Insulated glass is behind the iron bars. This is great for safety because it allows you to open the glass panel (from the inside) and still have a locked door with iron bars in front for protection. This allows you to receive small packages, talk to people, etc. without ever having to open your front door. I feel a lot better with this door when my wife (& kids) are at home alone. And these days, i always answer the door with a loaded & chambered gun hidden behind me. Paranoia gets the best of me sometimes....
2023 Lexus GX
09-27-2011, 03:20 PM
This is what i did today...bought 4 inch metal "mending plates" (4 quantity) at Walmart, then use zip ties to connect them together. With these plates attached to the sides of the slider (or whatever you call it), you can still pull down the release handle and push it back up. At the same time, it blocks any hooks from getting into the critical space.
2023 Lexus GX
09-27-2011, 03:23 PM
Super Moderator
Super Moderator
I won't be knocking.
'06 Limited V6
09-27-2011, 03:33 PM
Nah, just call beforehand with full description of what you will be wearing, anyone else with you, fax me your criminal record & driver's license beforehand, do not wear any sunglasses on that day, no hats, hands always visible in front, and please wear shoes that can be easily taken off for examination. But, the good side is that i don't own a body scanner....
2023 Lexus GX
09-27-2011, 04:11 PM
especially with "how to" videos all over youtube.
i do like the your idea with the metal pieces. smart and easy.
but still,
no better protection than the one that is on your hip.
2004 4Runner SR5 V6 2wd
My Build/Mod/Repair Thread
My Beauty Shots
