The OEM oil filter seems small
bwwwalker
Junior Member
The OEM oil filter seems really small for the engine. I've seen bigger on a lawnmower.
Has anyone installed a bigger oil filter like the WIX 57145? The threads, diameter and bypass pressure are the same but it's taller so there is more surface area.
I had the same concern at one time, however, if you are changing your oil/filter regularly you will have no problem. Cut the OE filter open at your next change and see how it looks, I've not seen any cause for concern. Not sure what P/N you are using, but the D3 is what I use on my V8 and it is larger than what was on my Highlander, so I switched to the D3 on Highlander too.
erinobr2000
