Check your rear tailgates people...
I had a creak coming from the rear cargo area everytime I drove up anything at an angle (like a sloped driveway as already mentioned). After endless nights playing with all of the plastic trim in the back, I focused my attention on the rear tailgate. I suspected that it wasn't being "held in" tightly enough, and that body flex when driving on angled surfaces caused the hatch to squeak.
Here is how I found the source:
I drove around the neighborhood one night looking for road features (dips, bumps, driveways) that would reproduceably cause the squeak. Obstacle course in place, I then opened the tail gate and placed a thin towel over the rubber stops on both sides of the back of the truck (next to the rear brake/blinker/tail light housing) and closed the tailgate again. If you look at the sides of the tailgate itself, you will notice two plastic bumpers that press against the rubber stops by the tail light housing when the hatch is closed. Since I suspected that the tailgate wasn't being sandwiched tightly enough when closed, I placed a thin towel in between the rubber stop and plastic bumper before closing the tailgate. With the towel in place, I was able to drive over all of the sloping surfaces with no squeak at all. It was completely gone.
And this is how I fixed it:
I removed the rear tail light housing and attempted to adjust the two rubber stops towards the middle of the vehicle (for a tighter sandwiching effect). Unfortunately, they were already adjusted in as far as they could go. So, I decided that the next best thing was to add a thin shim under the plastic bumper stops on the tailgate. I cut two thin pieces of plastic from a clear plastic carpet protector (rolled vinal) and installed them under the plastic stops. I drove around again and smiled from ear to ear as the squeak was no more.
That was 8 or 9 months ago and still no squeak.
It is also possible that fine tuning the latch receptacle and/or the tail gate hinges might also eliminate the squeak, but I am not that courageous.
Maybe this is your problem too?
