No power to factory trailer plug
lmoorefx
I have an 06 with the factory towing class 3 hitch. The positive terminal on the plug is not getting any power, I have checked the fuses under the hood and they are all good. Lights on the trailer work but the onboard battery will not charge. is there a hidden inline fuse for the direct power? Or what else should I be checking?
How about the converter in the trailer? Try this board - RV. Lots of help form very good people on all things RV!
There is a fuse in the connection box but its good, this is just a 20' enclosed car hauler.
I have hooked up a test light to the plug on the truck and with the key on, dont have any power on the terminal that says battery on the plug.
thanks for the site suggestion.
About 6"-8" of wire up from the plug is a union. That's where the plugs' wire joins to the wiring of the vehicle. At hitch install perhaps this plug wasn't re-installed properly.
:cheers:
