FS: Doug Thorley y-pipe for 4th gen with FJ tcase or FJ or 2wd 4th gen, IN $200
blackoutt
Selling a used but in nice condition Doug Thorley stainless steel resonated exhaust y pipe for all years Toyota FJ cruiser 2x4 and 4x4 or 03-09 Toyota 4Runner 2x4 only OR will fit any of the guys that are cool enough to put an FJ transfer case in a 4runner. Part number 89228. Will not fit 4x4 4Runner due to different 4wd actuator on rear of transfer case, this is my only reason for selling. Nice bolt on pipe with light use, comes prewelded in center section and with o2 sensor spacers, you must reuse or get new stock gaskets. $200 picked up in Columbus Indiana. Will ship at buyers expense but it won't be pretty.
Curious, did DT make one of these for the 4x4 then? Our Y-pipe is absolute shit.
No DT option for the 4x4 4runner unfortunately. There's just not much room between the actuator and gas tank. I don't like the under the transmission option from URD so I guess full custom it is!
Magnaflow makes a stainless y-pipe for the V8 4x4 4runner which does not have the reduced pipe and bottleneck.
Put one on about 6-months ago. Better throttle response and a little better sound, but weighs a lot less and comes with a cat for under $200
Do you have a part number? I only see their stock replacement parts with cats that look to be stock diameter and routing.
Edit: I see 93656 and 93657 for the 06-09 V8's. Maybe a little better flow at the y joint and pancake pipe but pricey ($390) for both parts.
I see 93655 for the 03-04 but doesn't look like that'll bolt up to my 50 state/4 cat setup. I'd need the other crossover pipe too.
AndiGarage
