Pics of my 03 Sport.
ToyotaDoodz
As requested. My avatar at full size.
My lifted 03 next to a stock runner. Mine's on the left.
S t r e t c h
Out play'in - - pre-BFG's.
Can't post a lot of my most interesting trail pics since my runner is not in them. Here's a few repeats . . .
Just below Gunsight Pass above Crested Butte, CO
My ExtremeAire Portable Compressor. 100% duty cycle is a must above 10,000ft unless you are REAL patient.
The "smooth" part of Engineer above highway 550. Very deceiving pic.
Imogene Pass, 13,114 ft.
Thanks to ImageShack for Free Image Hosting
How did you manage to shrink that large picture into your avatar and keep it so clear?
Every time I try to shrink a pic, it loses its sharpness and looks like crap....
If you tell me how it's done, I'll try to make one of my large pics into an avatar:cool: :D
your truck looks great!
I have one question, is your truck lifted 3 inches from the revtek in the front and back? or is the back lifted at a lower height?
I really like the lift on your runner.
really great shots...makes me want to head out to the wide open spaces now...if it only wasn't for the little fact of that job holding me back.....
Thanks everyone!
I use Adobe Photoshop 6 or Ifranview. First, I resize the dimension, then do a save as and in the quality window select 3. To get under the number of bytes you also need to save it WITHOUT the EXIF info. EXIF is the data about the shutter speed and exposure, etc. If you do all this, you don't need to mess with number of colors, etc. Ifranview is free and can easily do all this.
I have one question, is your truck lifted 3 inches from the Revtek in the front and back? or is the back lifted at a lower height?
Thanks! The Revtek kit is 3" front and 2.5" in the rear. It puts my 03 at slightly higher clearance than my stock 3rd GEN had. I wheeled this one stock and while it was very capable and could a lot, it was too low to do the trails I was accustom to running without scraping bottom. Some, I could not do at all. I was tired of worrying about what I was going to hit underneath so I did the lift. I haven't touched bottom since.
I hear that. I don't get to go nearly as much as I'd like.
Jesse1
