01 headlight problem
Took the switch apart, cleaned out dirty dilectric grease, no change. Replaced ground wire from battery to fender cowl no change. Battery power and power at bulb is the same however ground terminal on drivers side bulb shows 7 volts. When i hit the high beams all terminals on drivers bulb show 14 volts.
How are the relays? are they functioning properly?
What kind of Bulbs are in your headlights? Standard or LED?
I would very and trace the wires are good and not shorting using the wire diagram.
I would also very your headlight relays are good and functioning properly as there isnt a lot to the headlight circuits.
The headlight and dimmer relays would need tested.
Tested the relays and they seem good, 70 ohms resistance.
I just bought brand new halogen bulbs on a whim today and have progress. Passenger headlight functions as it should, low beam is bright and high beam is bright. Drivers side still brown on low beam and when you switch to high beam it turns off. Also im showing 7 volts on the ground terminal when low beams are on. I have power on both sides of the low beam fuses.
FIXED! The ground wire on the drivers side had no continuity. I attached an alligator clip to the ground tab of the bulb and gently slid the connector on as best as it could fit and ran the other alligator clip to the negative terminal. All lights function like normal. High beams, everything.
I didn't want to tear my harness apart so I took the plug apart and removed the ground wire. I slipped in a new ground wire with locking spade connector that I robbed from another harness from Amazon and ran that ground to the drivers fender cowl ground. Works great!!
Thank you all for your help, I was definitely complicating this.
Good deal you lost a ground wire and got it repaired. Wires can occasionally do that. Mostly its the relays. I figured it was a wire or relay not functioning but by the looks of that circuit with the Day time running lights, does complicate that circuit some.
As these rigs age, these kinds of things happen.. :-)
Yes sir! And thank you for sending me those wiring diagrams with the theory of operation. I studied those for hours in my down time. It brought me back to my days in the USAF troubleshooting faults in equipment...I miss that! Was nice to get back to tracing faults!
tuṣṭāva
