02 3rd Gen 4Runner (Slow build)
IMG_8432-1.jpg~original
[/QUOTE]
This is a really sweet pic!
Thanks fightman, its one of my favorites. There was a tower at this overlook that allowed me to take the photo. I was also able to stitch this together from there.
1237e698.jpg~original
I spent the day with my son in the Ouachita NF. We had a great time with a couple trails that almost kicked our butts.
Here's a link to my full post of the trip and below are a few choice pics.
• View topic - Ouachitas 5/21
This is a stitched panoramic shot of the spillway. Thats a road at the bottom with the posts.
1e28fe2e.jpg~original
Many of the roads/trails were washed out pretty badly from the recent storms.
b53ced85.jpg~original
This was our first water block. I didn't take a pic of the second but basically it looked the same way.
9a26ea34.jpg~original
We finally made it to our destination.
2e71686e.jpg~original
This is a daily commute for the lady in this 4Runner. She lives in the OuachitaNF and drives to Little Rock to work.
Looking good man, Your build is very similar to mine. You should include some pics of where u mounted the cb box and Ham radio main box. Also I would advise you raise up that ham antenna, right now your losing the ground plane affect by having the antenna below the roof.
Im still working on a place for my air pump, I put a second battery in your location. keep it up !
Thanks for the kind words. I have the ham antenna down below the roof line due to tight trails in Arkansas. If I raise it I will rip it off quickly. The CB antenna has already taken some pretty serious abuse.
Once I figure out a mount for the handset and the remote speaker on the ham I will post more pics. Work is really getting in the way of my build right now.
I was thinking of mounting my air compressor where you did but with it getting so hot I had concerns but really like that install. I had a couple minor problems with the hose getting weak at the compressor due to the heat so was a little Leary. I'm sure it will work well though.
tchughes,
Nice buildup. I have the twin brother of your rig, but right now it's staying closer to stock since it's the DD and I have a built FJ62 for trips and wheeling.
I have quick question about your Midland CB. I have a factory refurburbished CB same model as yours, and I've had a few issues with it when I ran it out of my old FZJ80 Land Cruiser. It seemed to get overpowered when someone close by was transmitting and everything was garbled. I couldn't for the life of me figure out why. Have you ran into any issues with yours?
Nice antenna mount by the way... I used to run a Wolcott mount, but I think I'm going to break out the plasma cutter and make one out of some angle like yours. Looks great. :bravo:
tchughes,
Thanks for the kind words chitown. I must admit that I haven't used the CB that much and really only have it for those small group trips where everyone has a CB instead of ham. I haven't taken the test yet so no transmit but I can already tell ham is the way to go.
The CB appears to work well but I will probably go with a different antenna soon. The last trip pulled the tunning portion out of the end of the antenna so its not doing much good at this point. Thinking of going with the 102 inch whip when on the trails.
Your build is awesome! This is direction that I want my build to go when I finally take it away from my wife and it becomes my weekend rig. What part of Arkansas are you in?
KMAYO, I appreciate the kind words. I have taken the summer off on the build and really need to get back on track.
I'm located in Bryant, AR.
No problem and your just down the road from me I am in Shannon Hills Area up on Emerald Mountain. If you want some help when you get your build started back this fall or want to go wheeling one day let me know. I not very experienced but hopefully helping somebody else will keep me from wanting to spend money that i don't have on my 4Runner!
Sounds good I would love to go out and hit the trials next time yall go out. Ill send you a PM with my info.
Do you know the part number for that 'trac off' switch.
I'm not able to check to see if there is a part # on the switch but will check this afternoon. A quick search on ebay found the below item and it looks identical.
Toyota Scion XB TRAC OFF Switch
This is a momentary switch that only makes contact when pressing the button, that's why I used a relay to actually disconnect the proper wire for the traction control. Also, you may be able to add back lighting but I never looked into that. :) Hope that helps.
7ron
