02 DRL delete?
racermech
My wifes 02 has DRL's, but they are on full bright all the time. She has a dash cover, but I dont see any sort of photo sensor that it is covering up to make them on full bright all the time.
My understanding of DRL's is they are just a low low beam, then you turn on your lights to regule full beam.
Is there are sort of easy delete to get rid of the DRL's? I am tried of switching out bulbs because they are always on and burning out.
Follow the link p nut posted. I've done this mod and it was very easy to do. You do not have to install the drl on/off switch as described in the article unless you just want to.
I simply snipped the correct wire on the drl module and volia! no more drls :D
Odd though that your drls are as bright as you say they are??
Ohio4R said:
Do you know if this will work with a 2000 SR5?
No. The drl systems between '00 and '01 are very different. The write up posted above will not work for you. However...
For a '00 4Runner, open your hood and look inbetween your battery and fender. You should see a small black box. That's your drl module. Simply unplug that box and you will have effectively disabled your drls. Plug the connector back in and your drls will resume. :)
Just cover the connectors with something to keep debris from clogging them.
Thank you!
