02 sport 4wd engaging problem
Kams979
having the issue with the 4wd not engaging properly. Started off with the normal acting up scenario having it not engaging right away or going through the motions of R-N-D to get it to set. Now im having the problem where it will only engage if I press the 4WD button "and the indicator starts to flash" I turn it off, then back on again and will be engaged but with the center diff locked. Once it is engaged I push the center diff button it turns off as normal. any ideas on what it could be? I pulled both sensors and cleaned them with some electronic cleaner and worked the switch but still having issue. thanks
2001ATL
