2007 sport AC problem
Drcoffee
Senior Member
This is a strange issue. My AC runs great, ice cold even in 100*F OK heat, no noises or fluctuations. Fully charged and verified by sight glass. What started happening is after driving, I park it, an hour later I start it up again and the AC button is flashing and compressor wont engage. Turning off the engine and restarting doesnt change anything. To me it seems electrical or possibly a worn clutch with too large of a gap to engage.
The next day, it starts and runs fine until I park it and it repeats again. This is a new thing, never happened before this August heat wave.
Checking Rockauto prices on compressors it would run about $280 shipped.
Where should I look first? Can the clutch be adjusted?
Thx
Thx
I think that AC button flashing should be setting a code. I believe there is a way to read it without a code reader or you could use something like a Bluedriver.
Here is the instructions for entering A/C diagnostic mode.
Thanks for that link. That looks to be more for head unit diagnostics. Nothing regarding compressor cycling. The more I search, it seems like the high pressure switch might be the culprit. The compressor seems to operate perfectly fine when its running. Even a worn clutch should squeal a little. I havent had much luck with aftermarket electronic parts for my toyotas. Got to find out what toyota charges for this part.
Im open to suggestion on other causes.
The items I'd check for a flashing AC light are, in order:
- Failed pressure sensor or wiring
- Wiring for ac clutch lock sensor (sensor itself is almost too simple to fail)
- AC relay (easy to check just swap with an identical relay in the fusebox but be warned if its this you're gonna disable whatever other system you swap with)
- AC """amplifier""" (hard to debug without having a junkyard unit to swap)
I doubt it's the compressor itself.
I don't know if it applies but this seems to be an issue with some Gen4s
A/C hot/cold - thermistor - read before replacing
It's not this if the AC light is flashing.
I replaced the relay already. Compressor seems fine. And it only happens when its very hot after running. I will jumper the pressure switch next time it happens to see if it turns on.that switch is a simple two wire plug.
Thx
RECHECK the hi and lowside pressures again, overfilled refrigrant is the easiest possible cause
I havent rechecked pressures yet. But it did shut down again on me. I unplugged the hi pressure switch and jumpered it with piece of wire, nothing changed. I reconnected the switch and the compressor came back on. Is the switch working or defective? I would think if the system pressure was too high, the compressor would not re-engage.
Bunkstaff
