03 limited vs 07 SR5
boldaddy
I would love to get some advice. There are two rigs locally that I'm considering.
1. 2003 limited v6 4wd 81k miles - he's asking $14,500
2. 2007 SR5 v6 4wd 89k mikes- he's asking $16,500
I would love to get some advice on pros and cons of these two. From my research the main differences I see ar cosmetic plus the 5speed auto on the 07. Anything else I should know?
Thanks in advance!
Glen
Thanks in advance!
Glen
The 07 will have VVT-i. Also the 2007 will have the newer projection style headlights as well as the LED tail lights. Sure you will probably get a sun roof with the limited, but the VVT-i in the 07 alone would be enough to make me pick it.
I guess it comes down to trim....do you like the trim options in the limited better than the SR5? And is a more modern motor worth an extra 2k to you?
BTW. IMO 14,500 is too high for an 03 even with the miles.
Wow, this is very helpful. Thank you. I didn't know about the engine difference.
Glen
Slight clarification, the V6 was always VVTI. It was the v8 that was not in 03-04.
The 07 sounds like a better deal. You can always add leather if you want it, but you will never get the 4 years back in value.
Jhunt
