03 T4R SPORT 4WD V6 all fluid changes HELP
retco
I"m taking my t4r to get all the fluids changed. transfer case, front and rear axels, coolent, and maby trans. Cant i get all the transmission fluid changed at once doing a flush, and not a power flush. Ive done spark plugs and air filter , cabin filter. WHAT ELSE NEEDS TO BE DONE. 03 T4R SPORT /3/2 CORNFED/ 285/70R/17 BFG KO'S. 115K MILES
Yeah, they have a thing they hook it up to that exchanged old with new, without flushing anything. Its the only way to get all the old fluid out and the new in. I will be getting this done, as soon as I get the isolator bushings done.
Since you have a 2003 then you have a transmission dipstick which means that you can change the ATF yourself and it should be replaced.
Flushing with a machine is controversial as it can contain some leftover AFT from the vehicle prior and since these transmissions are electronic it may move stuff into passages that transducers are measuring!
I replace my AFT every 30,000 miles with the type T-IV (I would only use Toyota stuff here). I drain it one weekend (which only drains about half the fluid) and then I drain it again on the following weekend.
