03 v8 rpm surges at stop then drop
fjc32
My 03 v8 2wd engine rpm surges when stop at stop light. It will go to 750 then back down to 400. Does anyone know why? Thanks.
Not sure if I have a full explanation, but perhaps a clue. Even if you kick the vehicle into neutral while rolling up to a stop, it won't go all the way down to a regular idle. I believe this is to make sure you've still got enough RPM for adequate power steering while still rolling. When you actually come to a stop, the RPM will finally drop to regular idle.
I've got a V6 and have seen this delayed drop to idle, but don't think I remember an actual surge. Maybe the situation is more complicated than I thought, and the idle speed actually increases a little more (for better power steering as you get to really low speeds, and then drops when you stop. This could be called a surge I suppose.
The V8 is significantly heavier up front and is in 4WD all the time. It might need a little more power assist to the steering to feel right at really low speeds.
Man, I can offer wild speculation with the best of 'em!
