04 rear window
steve5300
Would like to hookup my rear window to my alarm I have an extra output on my remote. I have it hooked up now but you have to have the ign on for it to work I know there is a way for the window to go down without the ign on because the keyless entry does it. Can anyone tell me how to make this work??
If nobody here replies, suggest you post your question on www.the12volt.com ... it's a mobile electronics installers forum and there's a wealth of knowledge there about installing aftermarket gear. Please share your answer when you receive it.
As long as you have aux. output on the remote you should be able to add a window module which cost me about $75.00. I did not do the install myself but it looked pretty straight forward. I am assuming you already have the module then it would need to be wired to power that remains hot all the time rather the switched power....This probably didn't help much did it?
Not much help but thank you any way dont think I need a roll up thing because the window already works with the remote just cant find the trigger the one I found only works with the ign on. :confused:
Sorry, I believe you will still need a window module that works with the alarm for it to work correctly not just a trigger...
ghengiskhan
