Bob, let me first say that Justin is an awesome dude, he's a great mechanic that will not sell you shit you don't need, and not gouge you on price. the job is BRUTAL, tell him what you want to have done, you don't want to do this job yourself, trust me it blows. I got the doug thorley headers, and 2.5" universal cats from Jason Burtman(awesome dude as well), also the Gibson stainless catback, two new OEM exhaust manifold gaskets, its probably a good idea to get fasteners for the headers in case they are shitty from corrosion. The y-pipe is the only thing we retained from the oem setup. and it was repaired and modified at Pop's exhaust here in Ct, because Justin doesn't have a pipe bender. my y-pipe had flanges that were moments from failure, but the pipe itself was sound, Nick at Pop's even stated that i should let him repair the stock y-pipe because being in the rust belt it would last better than an aluminized steel y-pipe that he could make with the bending gear he had.. you could go out and seek an aftermarket y-pipe and just bring all your new parts to Justin. also needed is two bung extenders
(2 of Blox Racing BXFL-00108 Check Engine Light Eliminator Adapter) because yes this install will have the truck throw a cel.
i have 3 cats in place, two new, welded to the headers, and the big sucker(OEM) at the backside of the y-pipe. the truck sounds so badass now, very v-8 hot rod sounding...I'd say call Justin his # 860.208.6869, tell him that you want the work done, then order up your parts from Jason Burtman.. I kept all the cats because it'll be a nightmare if not impossible to get it to pass emissions, some states do a visual, and you'll be screwed if they see you cut all the cats out, it still sounds amazing compared to stock...He had my truck for 4 days. once you hear it when its done, you won't be able to contain the big smile, it sounds so sweet. I can't really quote price for him, you've read around about the difficulty and cost of others that have had it done, trust he's totally in line and super fair.
