Um....no. Toyota is going to sell me a 27F TrueStart Battery, which is physically the same size as my OEM Panasonic. It also is rated at 710 CCA and 165 minute reserve capacity, just like the Panasonic that comes in the 4Runner. If I remember correctly, it also has a 7-year warranty. The 24F is a smaller battery, with lower CCA, and is a very common size so it's available everywhere.
The 27F from Toyota is the ONLY battery available that is the same size, has the same reversed terminals, and has the same CCA rating as the Panasonic battery originally installed in 4th gen 4Runners.
If you know of another source, let me know. I certainly couldn't find one anywhere other than the Toyota dealer.
Did you actually read the Toyota guide I linked or anything else I wrote? Let me try again.
There's nothing magical about the Truestart batteries, they're OEM'd by JCI for Toyota NA. 24F/27F are *standard* sizes with *standard* terminal placement. *Any* 24F/27F will fit the 4Runner without any problems...if it doesn't, it's not really a 24F/27F. I think you're getting this reversed terminal thing due to the 34R versus 34 that is required to make the Optima, among others, fit.
The Duralast/Interstate 24F both have more CCA than the Truestart 27F with about 30 minues less reserve...no biggie either way. 27F is two inches longer than 24F, same height and width so there's not that much more room to cram in more energy assuming the same chemistry is used. Chemistry is probably what sets the Panasonic apart.
The Truestart warranty is 2 years replacement/5 years prorated; clearly documented in the Toyota brochure link. The Duralast Gold is 3/5 for a total of 8 years. Not sure about Interstate or other options.
It's true that 27F is less common. Due to the *standard* sizing, a 24F will work in any application that a 27F will fit...same height & width, less length. When you can't squeeze in much more energy, it doesn't make much fiscal sense for a vendor to stock both sizes when the 24F will do everything the 27F does. Only marketing can explain why anyone still stocks a conventional 27F...Odysseys/Orbitals are a different animal entirely. For example...Interstate does offer a
27F, but it actually has less CCA than their 24F...and it has the same 710 CCA as the Truestart....no surprise since it's built by JCI, just like the Truestart.
BatteriesPlus actually offers a 27F with 850 CCA and even less reserve than the 24F. I'm sure one could find other brand's with 27F batteries with a little effort.
I don't care if someone buys the Truestart or Walmart's house brand, but you need to stop repeating this nonsense about the Truestart being the only acceptable replacement.
-Brent
