'05 Limited Seat Heater Switch and HVAC Head Unit Light Replacment
Buckaroo
Member
Have an '05 Limited and have a light out on one of the seat heater switches. I have removed the switch but not sure how to get the bulb out of the switch and have not sourced replacement bulb. Checked the FSM and they say you can replace the switch or, if you want, replace the bulb but they give no specifics. Would rather just replace the bulb.....how do you get the light out and any one have a link for replacement part?
Also, I have some lights out on the HVAC head unit and have the unit out. I identified this kit on Amazon and likely will get it and just replace all the bulbs. Has anyone used this kit or is there a better source? Suggestions?
Amazon.com: GENUINE TOYOTA OEM COOLER CONTROL CONSOLE BULBS (SET OF 10) 90010-09015 - 90010-09019 : Automotive
Thx,
Buckaroo
Id assume the lights in the heater switch pop out just like the HVAC bulbs. Id just order however many lights you need through the toyota dealer instead of paying $50 for more bulbs than youll probably ever use
To tie this up, the heater switch has two lights, a running light (which is removable) and an on/off light (which, I believe, is not removable). I need to replace the on/off light so I think the only option is to replace the switch which is $110.10 list....I'm just going to put up with the burned out light. Anyone have thoughts on replacing the on/off light, please let me know.
I did check out the Toyota part numbers for the HVAC head unit lights and the kit does appear to have a full complement of bulbs to replace all of them in my '05 Limited (10 plus one extra). Purchased individually from the dealer, they would be $57.20 list but I can get them for $43.00 plus shipping from Cool Springs Toyota. I will likely just replace what I need to at this time.
