06 keyless programing
064Runner_13
Does anyone have the sequence for programing the keyless (HYQ12BBX) on an 06 4Runner. I think the the program is the same on an 05 if you have that.
064Runner_13 said:
Maybe I'm blind or just plain dumb....but I can't find it. Any help?
Depends on what features you want to program. The owners manual has steps for the one's you can do yourself and directs you to the stealer for those you can't.
It's not the RS3200, and I only want to program a couple of extra key fobs I bought off of eBay. I'll try the suggestions you all gave. Thanks
Sorry, you'll need the stealer to do that ($$$.) If you just bought the truck then ask your salesman to try help cut you a deal or a freebie from the service dept.
I Found the programing for what is supposed to work for a 03-05 4Runner and it works on an 06. Keep trying...it will work. Keep your money in your pocket and out of the $tealer's.
1. Drivers door open, key removed from ignition switch
2. Within 5 sec insert and remove key from ignition switch twice
3. Within 40 sec close and open driver's door twice
4. Insert and remove key from ignition switch
5. Within 40 sec close and open driver's door twice
6. Insert key into ignition switch and close driver's door
7. Switch ignition ON and OFF once to program a remote transmitter while retaining the original codes. Switch ignition ON and OFF twice to program remote transmitters while erasing the original code. (Three times to check how many remotes are currently registered)
8. Remove key from ignition switch
9. System should now lock and unlock vehicle. Once, twice or five times depending on which mode has been selected. One to four times, slowly, to indicate how many remotes are registered
10. Within 40 sec press and hold remote transmitter's LOCK and UNLOCK buttons together for 1.5 sec and release.
11. Within 3 sec press remote lock button
12. System should now LOCK and UNLOCK vehicle. Once to confirm registration, twice to indicate programming has failed
13. Within 40 sec repeat steps 10-12 to program additional remote transmitters. Up to 4 remote transmitters can be programmed.
14. To exit programming mode open the driver's door
Note: pay careful attention to the timing of the intervals especially in steps 10 and 11. Holding the buttons too long or too short will cause the programming to fail. Multiple attempts might be necessary.
I think what your talking about Kmvreter is the actual key. I think when he says key fob, he is referring to the keyless entry remote. The programming instructions do work for the remotes. To program an actual key, you do have to take to the dealer.
