06 V8 - Can't turn off VSC lights
rikclark
Had problem with air induction pump, so purchased bypass kit that solved the problem. VSC warning lights were also on and read somewhere that had to resolve Check Engline light issue first.
So now, CEL is off but VSC warning lighs (including ABS light and traction control light) are still on. Have tried several solutions found on this forum from removeng gas cap and then disconnecting battery to ZERO POINY CALIBRATION (more than once) None of the above have provided permanent soluutions.
Sometime lights come on as soon as I start engine and step on brakes. Sometimes they come on only after a few miles of driving, and sometimies they come on after several miles of driving, and sometimes not at all. I'm open to trying another solution if you have one to suggest. Cncerned about ABS light and am not sure if ABS is functioning.
Mine turned out to be a brake pressure switch or something like that. The dealer replaced it and mine never came back on. It was like $250?? Mine would come on at odd places. And sometimes not at all.
If your ABS light is on, ABS isn't working.
When I had this issue, it was an ABS speed sensor. Go to an O'Reilly's, they should have a scanner that reads ABS codes and see what your code says.
