1" lift rear coils
Vantage
I would really like to level my 92 without spacers, so far I have found these options.
Discontinued Downey - 1" lift
NWOR springs - 1.5" lift
OME springs - 1.75" lift
Does anyone know of another spring that has a 1" lift?
if your looking to level it i would go with OME the .75 will not make a huge difference
Fixed;)
Thats to bad, I wanted to keep it low.
someone is selling some 33x10.5's locally for a decent price, but I will need to be level (and maybe some trimming) to clear them.
I was hoping 1" lift, and torsion bars to match.
Ahh well, even google shows nothing exists with a 1" lift.
2.5 inch lift is the best way to clear 33s correctly!!!!!
2.5 inch ball joint spacers and +2 inch lift springs. do it right or go home in my opinion
Thanks for the input BV, but I would like to keep it as low as possible. A little trimming never hurt anyone.
A member on yotatech did 33x10.5's with a 1.5" lift and no rubbing or cutting.
If you want to level it out, you might consider MOOG coil springs(#225) and replace the rear control arm bushings with urethane(suspension.com). Get them sent to Blaine and pick them up.
The rear suspension sag on these is not just spring failing, it's the bushings as well. The springs are about $80, and the bushings will probably run about $40. You'll be stunned the difference those bushings will have on the truck(better handling, no sag, etc...).
regards
