A/V1 said:6. is the power "in" from ignition circuit for the "on" lamp
5. (not used)
4. The switch switches ground in this application. This is the wire for the inverter relay which gets the ground through the switch
3. is the ground for the the inverter relay and "on" lamp,
2. illumination ground (through the rheostat)
1. illumination power
drapaki said:this is what the back looks like..
the metal used was some thin corner stripes used in drywalling... i think it's tin. lots of hot glue gunnage.
initially i was thinking the switches would go on the bottom of the seat, near the track.. but the guys at the shop put it there to match the factory location.. guess that's a good idea. makes it easier to play tricks on my passengers by turning theirs on high on a hot summer day.jimsi said:Are you using a relay for this and where are you getting the power from?
...nice install...also noticed the heated seats, how do you like the switch locations.
