‘14 limited leveling question
Duckdawg1
I have a ‘14 limited I’m wanting to level out and run 275/70/17. I’m sure they will fit now but the front squats way too much for my liking. Just took a measurement (center of hub to bottom lip of the fender) of the front compared to the back and it’s 2” lower in the front. Is this common on the limited? I see the options of lifts from 2”-1.5” but I think if I install this, it will still be raked. What other options are out there? Not a wheeler but goes off road every so often. Thanks for any helpful information.
http://www.toyota-4runner.org/5th-g...r-5th-gen-tire-fitment-guide.html#post1550444
Have you read through this? Seems like 275/70/17 should fit, depending on your wheel choice, without lifting. I'm not sure leveling will give you much extra room for tires anyway, but I may misunderstand the benefits.
I’ve read through that link. I’m sure I can fit the tires under the truck now but was just curious if my measurements were common on the limited. Seems if I did the common 1” leveling spacer, I would still have the stock rake look. Just not so drastic. Now, if I did the 2”-1.5” it would still be raked. I guess my question should have been what are other limited owners doing to eliminate the sag and level their 4Runners out?
Yeah, I don't know that answer, but I bet if you search around you'll find that here. Plenty of people have used spacers to level and almost everyone shares their feedback, often with pictures. Good luck.
My '14 Limited was also exactly 2" taller in rear from factory. Installed 3"/2" spacer lift and now rear less than 1" taller as rear lift was more of 1-1/2" than 2"
