14' Trail 4Runner w/ new wheels n tires
ar15kittykat
14' Trail, Level8 Tracker 18x9 et0, Nitto LT Terra Grappler 285/60_18.
4Front.jpg~original
4Front2.jpg~original
4Front3.jpg~original
4Front4.jpg~original
4Front5.jpg~original
4Front6.jpg~original
Do they rub?
In front inner fender well when in reverse, full steering wheel lock, touches about 1mm at front point where there is a DIY thread on inner fender well adjustment sticky. I did that minor adjustments, no more rubbing.
Also front mud guard needs trimming, I just removed them altogether.
These Nitto LT contact patch are wider than all others, these 285/60-17 are Same height as Oem 265/70-17 but with wide 10" contact patch, very surprised these aggressive treads are so quiet, taken her up to 90, and almost as quiet as oem tires.
Thanks, this setup is exactly what i have been looking for, i hope you dont mind if i plagerize it.
Looks good! What I really like is that from a distance, those look like polished '10-'13 Trail wheels. They go really well with the silver paint. Lots of ugly wheel choices out there. Glad you didn't pick any of them.
plan to lift your 4R ?
Not planning to lift, not rubbing at all w/ full load of folks on fast dip, full lock, etc... I like the small rake, and I like the classic MickeyThomp hole wheels for trucks n SUVs... I'll add to wheel/tires section when time permits...
Not planning to lift, not rubbing at all w/ full load of folks on fats dip, full lock, etc... I like the small rake, and I like the classic MickeyThomp hole wheels for trucks n SUVs... I'll add to wheel/tires section when time permits...
"Not planning to lift".....:lmao:
We all remember that thought...
Well, coming from sports cars background ownership that are slammed to the ground, this is my 1st truck/SUV, and this 14' 4runner sits as high as an f150 fx4, I feel air sick ;-)
It is an adjustment on corners speed when switching from Viper to 4runner n back...
ccw1.jpg~original
IMG_4793.jpg~original
1-1.jpg~original
4Front.jpg~original
Love the tyres looks so much more mean than the OEM tyres, it has a very aggressive tread goes with the 2014 look. Do we have any such choice with the stock 17 inch wheels. What made you decide to go with 18 '' wheels.
Thx.
Goto nittotire.com, terra grapplers are available in 17s but w/ oem 17x7 sr5 or 7.5 trail w/ oem offset in 13-15s, u're not going to be able to fit 285s, it will hit UCAs hence folks do spacers or new wheels w/ less offsets.
I wanted 18s cause less sidewalls than 17s.
Didn't want 20s like LE cause I do off roads when hunting...
Laredotx
